Stao quick question. Its really pointless but thought I'd ask.
The green XR6T known as toxic has a bent exhaust wheel fin. It produces a sound like a supercharger.
Video here.
Guy claims it doesn't affect performance. Can you do this on one of your turbo's and achieve this sound or was his by sheer luck lol. I don't care what anyone says but it sounds awesome.
LoL no. I would pull it part and replace the exhaust wheel. Unfortunately Garrett no long sale rebuilding parts for their own turbos, so it needs to be fully overhauled. I would not buy that car the way it is.
Some news for SR20det lovers
This is the latest ATR28SS1.5 It is engineered to peek 260rwkws on pump 98 with supporting mods while has a stock T28's response.
Cool!!
Any dyno graphs?
For a fairly stock setup, when does full boost come on with this turbo?
Currently only have results from it on a Rb25det with larger turbine housing. That made 298rwkws on 21psi with full boost by 3600RPMs.
SR20det using a smaller .64 rear should behave very similarly. But no SR20det result on this turbocharger so far. This customer should have a result for me very soon.
Bargain!
So let me get this straight. Its smaller than the the ss1pu, makes more power and is more responsive on an SR20
Have i understood this correct?
Cheers
Hey Morgan,
It's smaller than the SS1PU and will make less power in total. Stao is referring to his E85 results, where his SS1PU E85 result was over 320kw IIRC.
I have forgotten to PM you in some time so are due for a catch :) PM me if you need me to clarify.
Hey Morgan,
Hey Man hows it been?
I'm a little confused bro, stao's post above states 260rwkw on 98 not e85. I want as much response as possible and it seems that the ss1.5 will deliver the same power earlier on than the ss1pu but the ss1pu will make more up top.
Sorry, I saw his response of 298 which is E85, missed the 260kw bit.
Remember these figures are based on his testing with the RB25, so while he knows it will have about 260kw worth of flow on 98 that is also compared to the SS1PU having nearly 280 worth of flow on 98.
Stao are the smaller SS wheels still based on the original high/low blade design or are all SS turbos now using the same straight blade design as the SS2?
    • ouch! how is the car now?I had sold my gtr but have been looking into some on trademe and a 260RS but I wouldnt be keen on any repairs needed on them
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
