Stao is it possible to put any of those units on hold?
I have a build coming soon which would be fantastic with one of those turbos.
Yes, got plenty of bits ready to start when you are ready.
Also recently got a CNC lathe in place, unfortunately no one knows how to get this thing to work. I'm having a programmer in next week setting up some programs for compressor and turbine machinery work. It will be able to save heaps of man labor and work at a much faster rate. Overall saving will be put on to our customers.
  • Like 1
Has the SS1PU had many changes in the past year or so since I purchased it?
I'll be pulling it out closer to Christmas and putting it into another car but will send it to you to upgrade it if you have come up with different options for it.
Cheers
Cheers
SS4 alpha CBB+VNT.
DO IT top bloke!!
  • Like 1
Been a while since I posted in this thread!
It's been a long time coming, but I finally got the SS1PU running on E85. So while ya'll gawk over top end power and laggy dyno queen status, here is a win for the guys chasing factory response and look with not so factory power :P
Bottom red line is existing 98 tune
Top red line is E85 with cat
Black line is E85 without cat
All @ 15-16psi
Now, some important things to remember about this setup:
It has a 20rwkw gain in the top end, over the 98 tune, which you might say is not much for an E85 conversion. But look to the midrange and there is nearly 35rwkw gained in some places. It is a very engine safe tune at only 15-16psi.
Obviously there is a top end restriction somewhere, but I didn't want to go replacing factory looking bits here and there with modified gear to chase some ponies up top for the sake of bragging rights. Being a daily driver, I care more about the low down and the midrange; the big area under the curve that starts very early in the rev range. This is what makes for drivability.
Consequently, binning the cat was as far as I was willing to go to improve the top end and that did give me some extra midrange, plus another 11rwkw up top. We originally thought the cat might be the big restriction holding us back up top, but the reality is that it was just one of many: My engine has a return flow cooler, factory intake piping, internally wastegated turbo that is highflowed into a Nissan comp housing and a fairly quiet 3 inch system. Ergo, my engine bay, with the exception of my pod filter (because I love the sound), looks COMPLETELY STOCK and has 272rwkw to boot.
As for the on-road experience, wow. The SS1PU was already something special; I've said it many a time that anyone looking for a daily drivable RB25 with some guts should opt for one of these turbos. It just made my car so much more driveable off and on boost than the standard turbo. It really is the perfect compromise between power and response in my opinion. This was before ethanol! With ethanol, my car comes on boost as fast as the factory turbo did. And when it comes on, the boost gauge spools up like a friggen tacho revving in neutral. The power is still very linear in delivery (as you can see on the graph), which is great for tyre grip, but don't get me wrong...the pull is ballistic. Any SS1PU owner will tell you that 3rd is their favourite gear because the turbo is a torque monster and just keeps pulling like a V8 at high speeds in higher gears. Well this is that on steroids!
I will have a go at converting the speed on the graph to RPM like I did last time, so you can get an idea of the response. But you don't really need it to see how early it gets on or how fast it ramps up.
And then there's the the smell of sugar and PVA glue while you're sitting at the lights...
  • Like 1
Prior to ethanol, I was pulling away from a VE GTS in 2nd and 3rd. This tune should give me the edge on some of the quicker Eurotrash; M series Beamers, entry level 911s etc.
Might have to get the old G-tech out and do some 0-100 times. Won't be an accurate representation given 1st gear doesn't really work anymore lol
Awesome to see birds!
When I get my new car and transfer the SS1PU over then I will be following the same route.
Might even send it off to get stao to put it into the factory housing depending on costs involved.
Loving how responsive it becomes on the E85
As you said they are already an animal turbo on 98
Ethanol is the ducks nuts. Got my flex fuel setup 90% finished last week, car struggled to make 320rwhp on 98 and then went 390rwhp @19psi on E53. Love the stuff!
Birds, you planning on hitting the strip to back up the numbers?
That is about the same result power wise I got with E70 and a GTRS . Like yours I use all the std plumbing inc the air box and snorkel and with a Blitz return flow IC . Granted I do have a bit of porting and Tomei 256s , and a Nismo exhaust with a large body ceramic cat .
I'm guessing the Hypergear has a bit more turbine and housing than a GTRS which should make it rev a bit faster .
Good result cheers A .
It's interesting you say that, because previously we drew comparison between the SS1PU and the HKS GT-RS in terms of power and response. So it doesn't surprise me that your ethanol results should be similar. Props to Stao for making something that can hang with top shelf Jap engineering!
The more I drive it, the more I love it. It just has oodles of power everywhere and I never feel like I'm in the wrong gear. The ethanol not only reduces the amount of time spent off boost, but makes off boost a quicker accelerating range to be in, adding to drivability. Looking at the torque graph probably tells this story better. Loving decat sound; how I missed the rasp and deeper note.
Took a bit to get the car started today...now know that feel bro re: winter starts for E85. Interestingly though, once warmed up the car starts quicker than unleaded did. Look forward to reporting on economy or lack thereof come fill up time.
The converted know!!!
Yup that is the plan, however I don't think I'll do it justice with strip numbers. I have 265 Toyo R1Rs on the rear and, whilst a great tyre in the corners, they struggle off the line; 1st is practically useless; I'd have to baby it, so there goes my launch. 2nd can hold with a good grippy section of road, but we'll try anyway!
Lucky most of my racing happens in rolling drags at higher gears :)
Good work birds, some thing like that is ideal for every day driving.
Yes the SS1PU has been upgraded few times since. The latest one is engineered to prevent the level of boost tappering in upper rev range more specifically for an internally gated application. So with few more psi of boost it will have better upper rev power and torque.
Interesting that. Mine cold starts as easily on E85 as it does on any other ethanol percentage. My car is honestly just better at everything on ethanol, though admittedly on full 85 the economy goes out the window haha. But I just keep it at about E60 so that I get the full knock resistance and most of the other benefits of the fuel, without the huge amount of extra fuel needed. On the track I'll use full E85.
Dont even worry about your ET until you get some practice. Your trap speeds will tell the real story.
One tip for improving your times though - don't worry about racing the guy lining up next to you. Just do your own thing and don't worry about the start light, your time doesn't start until you move so until you can get the launch and things down there isn't much point trying to race. Loads of fun though :D
Hi all, I've got an ATR43-SS2 going in the car next week, it's an R34 GTT. I understand it's a bit of a tight fit, are any of you guys running the OEM heat shield (or an alternative) with this turbo?
Manuel Kasko, on 29 Sept 2013 - 13:36, said:
Nice stao.
Are you able to do that inside of a stock R34 turbo?
Can reuse factory compressor end, not the turbine end. Which gives it a factory look.
Birds. For the drags you will need some 275 MTs, run them at 18psi, and worm them up nicely. If the launch is perfect then a good time is more promising.
One thing I didn't like about Heathcote is how they washes rubber residuals at the start of runway with water every time a car lunches. So we always taking off on wet tires.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
    • Sorry, just assumed that talk of coloured pads meant EBC red/green/yellow/shit stuff. I don't know the DBA pads, but it's a reasonable bet that they will be OK. DBA make good stuff generally. Those 4000 series rotors I linked to are very good. I may well replace the RDA rotors I have with those when required.
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
