The Nissan IWG assembly can be unbolted. Can use a Vband assembly as above or my personal preference bolting up a flange plate with a 3inch pipe welded into the flange.
like below:
http://www.hypergearturbos.com/images/atr45rear.jpg
The key to success is buy and work with quality. It took a while, I've managed to pickup a worked S14.5 with engine fully built by Forced motor works and tuned by Chequered Tuning that is very properly done with lots of goodies.
Gizzmo boost controller (tuned for 21psi running on 19)
Autometer wide band AFM
Boost gauge
7000km rebuilt engine with 260rwkws (built by forced motorworx)
BC 260 cams
Drift Exhaust manifold (low mount)
RAS (rocker arm stoppers)
CP pistons
BC rods
New turbo (Garrett 30-71)
700cc Nismo injectors
Nistune chip (tuned by chequred tuning) 260rwkws (with dyno sheet)
Custom air box
PWR radiator and intercooler (intercooler is inside engine bay so no chassis cutting)
Custom aluminum radiator overflow
Cusco front strut brace
HKS coil overs all round
Greddy oil sump
Spit fire coil packs
New varex exhaust system
100cell race cat
Z32 Air Flow Meter
In which will it be used in developing T2x based turbochargers for SR20det motors.
With VCT been cancelled. The GT3071R turbocharger in a .64 rear housing is horribly laggy for this SR20det. After driving it 63kms back, I have to admit:
RBs are Awesome.
Lets see if I can manage to same power with heaps better response.
Good score Stao! Sounds like a fantastic platform.
Its horribly laggy. I have a dyno reading from Trent before went to see that car. It makes full boost at 4600RPMs. enough revs for me to pump 490rwkws out of the R33. Since its been sitting in garage for a long time I think its got some fuel pump issues cutting off randomly on boost . Its going to be taken back to Forced Motorworx for a full check up before pumping through 24psi.
Lol.
My stock SR20 with a GTX3071 in 0.82 makes boost before that. Something wrong in the setup.
Btw, saw a 180sx running a gt2871 trap 128mph... Full interior.
But yeah, super excited to see SR development. :)
If I can get VCT enabled that should make a huge amount of difference. Its currently on cam gears. need to get this fuel problem fixed first. So will come to that abit later. any one knows SR inside out in Melbourne whom's interested to do some work?
If I was in Melbourne I could have helped you out
Know sr and s chassis fairly well
You will need a bigger walbro pump if you going to run e85 anyway and larger injectors
Go walbro e85 pump 460lph rewired and just get those 1200cc side feed injectors you got for the skyline work ok on s14/15
Get rid of that stainless manifold and put the std cast one back on as that will be where 500rpm lag will be and it's normal for the cropped t2 version gt3071r to come on boost at 4-4200rpm depending on boost
Get rid of those adjustible cam gears and put VCt gear back on will drive a lot better
Will my turbo be finished before the end of the year ? If not I'll just wait till January cause there might be delays in post anyway due to Christmas and new year thanks
whats the dags?, sounds like something sheep get...lol
cheers
darren
FKN LOL, missed that. What a dag!
lol yeah more that I want to compare mine to this 260kw lag monster. Not that 117mph is crazy or anything haha
I want to head out to wsid again to test out my atr28g2 next wed before I take it off for the ss1.5
Hopefully should trap 123mph+ as last Time I only got 2 runs and my cooler hose kept blowing but managed 1 clean run on low boost 20psi but still got a 12.4 @ 120mph
Now I got the 20psi actuator and before my twin tip varex had a resonator in the tips which look to neck down to 2inch which I removed and the centre hotdog
Should go good hopefully I can get closer to the 11s
LOL @ SR circle jerk. I'M IN!!!
Haha, last outing I destroyed my clutch and am since still waiting. Japanese tracking either says its on the ship or in the ocean somewhere, I guess we will find out in another 7 or so weeks lol.
Yeah, should be able to do that. I have a track day this Thursday, so if nothing blows up, I'll be in.
Car was originally tuned at Unigroup (290 as well- their dynos are identical I've found from personal experience), however I use DVS Jez, and has been to him quite a bit. Stock S14 motor, incld headgasket. GTX3071R 0.82 housing, 6Boost, 44mm Tial. 289kw@18psi on 98.
Lets go and see what they do, if I make it through the gearbox! :P
Also, can i get a rollcall on who is using what dump pipes with their turbos. I was using a (very old) JJR Bellmouth with an internal gate SS2 and the wastgate flap was fouling on the dump.
Thinking about buying the same thing again, but want to see what others are running, as smoe form of boost control would be great :)
:woot: waoo 435rwkws with 200rwkws by 4000RPMs out of a Rb25det. Pretty crazy if you guys high flow a turbo to do this I high mount it.
i have the same turbo from kinugawa GT3570 / T04 hybrid
full boost at 3800 rpm with walbro 460lph pump and 1200cc injectors
this shit is insane at 28 psi
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
