I test fitted my Kando/Hypergear td06 last night.
The fly cuts on the turbine housing aren't wide enough, so the nuts foul when trying to tighten the turbo to the manifold
Are you using 17mm nuts? Never had an issue with 14mm nuts, I just fitted one the other day.
You could just run thick washers under the nuts to clear the flycut...
  • Like 1
I have 3/8 UNF studs in the manifold, so the nuts are 5/8" (15.87mm) across the flats.
Also had to enlarge the holes a little...looks like it was designed around pissy 8mm studs
10mm might have just gone through, but after measuring it, the hole centres aren't square on both the turbo and manifold...by maybe 0.5mm...but enough that it required some massaging...and still needs a little more.
Going to enlarge the holes to 12mm and figure out a way to make the nuts work...cant even fit washers on there
Does the housing look like the one above?
Sounds like the flange on the manifold is out. What is it? And who the hell uses imperial crap on a Jap car... :P
Add in another update. This is our latest TD06SL2 based turbocharger, the SLSS-2 in 10cm turbine.
This particular one has the latest low friction trust setup, with slightly larger compressor inducer and slightly more aggressive compressor blade profile. It should be maxing out around 390rwkws mark working with a RB25det engine on E85.
It is made to produce more power, with better response and much better reliability to some of the T67 copies
Will update results shortly.
How much for this turbo? It's almost time for me to buy one
  • Like 1
Yes it is lol
The cut on the turbine housing is made for 14mm nuts.
Cheers. Will grab some 9/16 od ones and modify some washers.
Will be all good :)
Very happy with it for the price
Yes it is lol
Awesome! Getting so keen. Now I just have to find someone who will fly to darwin and tune my car for me :(
What is the inducer/exducer size of the compressor? I am about to buy a new manifold so no longer restricted by Trust 3 bolt flanges on my TD based turbos
I'm interested to know how these compare to GT3076Rs and if BB centres are an option . I still think the gap is a bit wide between GTX3067R and GTX3071R and while the HTAs look good local service isn't .
Tao is that comp housing a 0.70 AR T04B or T04S sized one ?
Also how do those TD06SL2 turbines compare to GT30s in your opinion ?
Cheers A .
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
