Yup looked at that and assumed as such...
Mate seemed to think one curve was stock (lower output) vs hi-flow. I said that I would find it hard to believe and that its hardly worth the upgrade if a standard turbo can make ~230RWKW reliably
They are high flowed on different boost levels. They are actually same chra used in Std 21U/OP6 high flows. Steel wheels and very reliable.
Above is from an Auto 1JZGTE, compare to the manual version it is roughly 10% behind in power.
Hey Stao
I've been out of this thread for a while but I've got a couple of questions.
Its hard to find new CHRA's for stock rb turbos, how much would it cost to make one that fits into stock housings?
My neo turbo is on its way out but I don't want to highflow because it would then need clutch, fmic, coilpacks etc etc, I'm happy with how it performs as it is (its just a daily)
I was thinking the other day, there must be a few people who want a rebuilt stock turbo that won't need to be tuned afterwards.
Would this be something you could make for a reasonable price?
A Neo turbo is basically like any other RB25 Hitachi but usually with the larger OP6 turbine housing .
Tao could tell you but the Hitachi centre housing is of similar dimensions to the old Garrett T3/T4 water cooled bearing housing and from memory the water banjo thread size is the same .
The Garrett centre needs a Garrett T3 sized aluminium compressor back plate and the Hitachi compressor housings are almost the same sise where they clamp on . The Hitachi back plate is part of the centre housing casting .
Minor machining lets the Hitachi turbine housing fit the Garrett style centre housing .
Long short if you can find a serviceable RB25 Hitachi turbo use that with your turbine housing if it's the larger one .
A .
The 310rwkws run above was from our standard R33 21U high flow.
Well, I won't be able to rebuild stock Rb25det turbocharger, because in most of cases it the shaft does snaps off the turbine wheel when I undo the nut.
I can high flow it using a smaller profile If you like stock response and drive ability. They are pretty sweet on stock boost working with factory ecu.
Dark blue is the G1 high flow, while light blue is standard turbocharger:
Based on a R34 GTT with Rb25det Neo motor, with supporting mods and pump 98 fuel:
It won't make a lot of power tho, I recommend standard profile if supporting mods are planed. The cost to high flow either profiles are the same.
So you couldn't make a chra that the stock housings would bolt to without needing the housings to be machined? I'm assuming here that machining the housings to suit your chras and new wheels is a bit labour intensive
Majority of people wants them high flowed so I didn't look into making a drop in core. I mean if you can't take your car off the road I can send you a high flowed OP6 turbo.
More that I can't justify the supporting mods to make the most of one of your turbos. I will be selling in the next 6 months too so would prefer to fix up the turbo but don't want to outlay too much money as I won't recover it. And would prefer something new rather than swapping an unknown stock turbo onto it.
Over the years I've seen a few Stagea owners searching for a similar option as the car is just a daily driver for them, surely some skyline owners would also like a core that they could throw in and not worry about exploding and run on a stock tune
For 10psi or under, it works pretty fine with stock ECU. The profile above would be as close to stock configuration as possible. But at moment I don't have a drop in core to replace the factory chra.
Pipster11: Please check your email. I've forward you with a special offer on an high flow service. Cheers. :yes:
Results sent in from another customer. This is an ATR28G2 on an S15 with tomei drop in cams making 227rwkws @ 18psi on pump 98 fuel. I think it is an fair number considering the car has been mildly modded to be street legal. Customer is mentioning stronger actuator with more free flow induction, cooler kit and exhaust in near future so hopefully seeing an higher numbers from it soon.
Also noticed the dyno run was using 5th gear?
Cool, Working on an ball bearing version of TD06x based turbochargers at moment. Pretty challenging so far as the bearing housing is very short and cast without much materials in it. lol. I will up load photos once completed.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
