Hopefully this time the highflow lives up to it's expectations as I don't really want to pay more money to be disapointed again. Stao I will send you an email so this can be arranged in the new year :)
I can guarantee you won't be disappointed. Can't be bothered scrolling back to find out, but please make sure you have a tuneable ECU also.
  • Like 1
For 260rwkws, sell your OP6 and buy and send in a blown R33 turbo. Once that is high flowed, it will be making around 260rwkws with factory responds.
Got the GTR pulling 404akws today using a high flowed blown kando T67 (from Peter). And did back to back test with few different coolers, will upload results shortly.
  • Like 1
Wouldn't the r34 turbo be better for highflowing or does the lager rear create a lot of lag? My car has the below mods so the only piece to the puzzle missing is the turbo.
Apexi Pod
Nistune
Npc Heavy Duty Organic Clutch
Apexi AVCR boost controller
Full 3.5inch zorst
Nismo Fuel Pump
Z32 AFM
Siemens 550cc injectors
Yellow Jacket Coil Packs
HDI Front Mount
So as you can see my car is capable of making some decent power just need the right turbo to do so.
Edited by DoseVader
it is wonderful that you came to this realisation yourself.
incidentally plenty of info from a search.
you are in fact all set for a sweet setup after highflowing your R34 'OP6' turbo
enjoy
enjoy
Can't be any more laggy then my current highflow setup, full boost at 5,000rpm thats living barry
Then you'd find the r34 hypergear highflow a blessing
I still need to sort my Pfc boost control setting out properly to get the boost right in the upper mid range, but it pulls nicely from 3500 rpm onwards, got 276 rwkw, power delivery is very linear and easy to drive
Good part about the highflow is it essentially bolts on, so installation is easier if you're doing it yourself.
Anyone feel free to correct me if I'm wrong but I thought the ss1PU is designed to be able to pull the same max power as the OP6 highflow with even better response?
Yes SS1PU is made to do the same sort of power as the OP6 high flow but with stock alike response, thats a very good option as well.
As mentioned earlier I've upgraded the intercooler on the R33 GTR from 600x300x68mm to 600x300x100mm. Using the same ATR43SS25 Alpha turbocharger, it managed to hold more boost on less boost controller duty, 10 degrees less in air temp, picked up more mid to top range, and the penalty in response is 100RPM.
By now, I have a good platform for turbocharger related evaluation and testing.
Also for few customers reports boost tappering issues on their RBs. Check your pressure drop across your intercooler. Some of you might be surprised of how much boost it actually restricts.
Below is a dyno log on a ATR45 using a return flow cooler, with customer defending for his 20 Cents junk.
Green is before cooler, and Red/pink is after cooler.
I found this issue with people using Blitz front mount and return flows also. If this is a scenario on your setup, get a tube n fin, 600x300x100mm cooler, we can supply that for under $200, and that has been tested and works.
+1, get the high flow - meets all your requirements and lighter on the pocket. I got the SS2 because I wanted a dyno queen LOL
Tell the truth Johnny you just wanted GAAAAAAAATTTEEEE! :D
Intercooler restriction. that car made identical amount of power using OP6 high flow, SS2 and now a G4 (3582 equivalent). They all can only be boosted to 16psi with actuator disconnected. Similar behavior to when I was using stock GTR33 cooler, this one is alot worse.
This is result from the Peter's dead T67 earlier, It is now rebuilt and high flowed running our ATR43G4 CHRA assembly, pulled 404awkws E85, fuel pump leaned out. Its now tested and ready for pickup. This assembly is good enough to pull around 430awkws with a new pump. I don't think I will be chasing for more power at this stage, But will be working to get better response.
Video added:
Told ya so Mark lol ;)
Hehe, that you did Mick. Been plenty of decent results with Blitz coolers before though (at around 250-260rwkW Mark), which was why I was wondering if the pressure drop is more noticeable at higher boost.
Anyways, thanks for posting those results Stao.
ATR43SS2.5 Alpha final run on E85, GTR-R33. made 367awkws on 20psi.
I've included dyno videos of the same turbocharger running both P98 and E85 fuel:
Fine, I'm not going to lie. I wanted gate LOL
Fek all those Honda homo vtecs, I has gate... Don't be mad :D
Exactly what I thought when I bought my blitz return flow, time for a new cooler it seems..
What cooler was it Tao?
Edited by owen1r
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
