The 53mm GTRS turbines don't work with RB25det engines very well.
The SAT stands for Special application turbocharger. This one is made only for Rb26 and Rb25 turbo engines working with large external gate setups.
We can high flow them to -5 or -9 depending on the HP chasing for.
With the damaged -7s I need to have a look at the turbo, the smallest billet wheel that I currently make is in 60mm that made 250rwkws on P98 on my SR20det.
The -9 idea sounds the go, what's involved in that and can it utilise the billet wheels
Also an idea on pricing, PM if needed
I have also posted in the Kando thread about fitting the 20.5g TD06SL2 onto a RB26 manifolds in twin form
Car is going in for tune next week with the 21U highflow and I can't decide which injectors to use.
I have a set of S15 440cc injectors (cleaned and flow tested) or potentially a set of used Nismo 740's.
If the 440's are enough for around 260rwkw (keeping conservative AFR's and safe injector duty cycle) I'll use them. If not I have to shell out for the 740's.
Car will be running PULP.
Why not just grab a set of ID's/xspurts? They're pretty cheap and have a 725cc injector and have E85 capability should it become available near you. Not sure what a used set of 740's goes for but I'm sure the xspurts would only be maybe 100 or so more
I want to keep the factory side-feed rail for now.
The 440s will be at or above max to make ~260rwkW. Will do it, but will not have any of that safety factor you were after.
I guess that answers my question!
Hey,
Recently purchased the newer version of atr43ss2 (internally gated 17psi actuator)a few weeks ago. Vehicle has following mods :
Nistune
Dvs custom metal intake 3" with breather and returns
Factory air box with high flow panel
Z32
Braided oil lines
Jjr dump/front pipe 3"
Catco race car 3"
Turbosmart boost tee
Ngk-r BKR7E 0.8mm gap
Blitz return flo cooler
Nismo muffler
Nismo fuel pump
Id1000
Dvs jez tuned vehicle and was only able to safely make 230kw going from 18psi Down to 15psi.
Elimination tests:
Removed top of airbox and tune ( minimal gains)
Removed muffler and tune ( minimal change)
Checked boost leaks etc
Running shell 98
I'll get the dyno graph and other details when I pick up vehicle.
Dvs tuning advised may be the return flow cooler causing the issue.
Any advice. I'm stumped.
Check pressure drop across the cooler. I see this happens with certain model of blitz coolers. Also pre-load the actuator abit more.
Green is before cooler and the rest is after.
  • Like 1
Any idea on duty cycle at that power level?
That was about 95 DC at factory pressure, I have since upgraded pump and bumped base pressure up 5psi and car has since made 293rwkw with new rings and bigend bearings and HG on same boost level
95DC is not advisable, but I was trying to achieve something which I am 0.14seconds off :(
Edit : with the way I have my car set up it is very good on fuel and has got over 630km from a tank full
  • Like 1
Hey,
Nistune
Z32
Braided oil lines
Catco race car 3"
Nismo muffler
Nismo fuel pump
Id1000
Elimination tests:
Running shell 98
when you say 'safely' make .... was the engine knock limited?
  • Like 1
Hey,
Nistune
Z32
Braided oil lines
Catco race car 3"
Nismo muffler
Nismo fuel pump
Id1000
Elimination tests:
Running shell 98
3 things I see MIGHT cause you issues
1) JJR dump pipe ( this is a copy of the HKS item and that was never really much chop )
2) boost T will cause boost to tapper off
3) return flow cooler could be causing pressure drop, Stao has graphs of this from his GTR
  • Like 1
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
