E85
Nistune
44mm External Gate ( of housing, by mr scotty )
1000cc ev14
Walbro 460
HSD coilovers + bunch of other suspension parts
Standard head/standard block/standard exhaust and intake manifold
Just jap fmic
Ran a flat 12 last night using cheapy westlake rs tyres :P
Very happy, its all in the launch
Now to try for 11s!
SS2 @ ~20 psi /~ 400hp
E85
Nistune
1000cc ev14
Walbro 460
Just jap fmic
This makes me want to finally get my car done and put the EV14's in and fix the exhaust up. I have everything to do it just need to find the time and money for a tune. Plus we have just got E85 on pump in town so looking at flex fuel now. It never ends :P
Very promising results on the SS2, mine is a little down at the moment we think due to the exhaust, and I think I may bump a few more PSI into it when it is tuned next. If I can match your results I will be happy as :)
E85
Nistune
1000cc ev14
Walbro 460
Just jap fmic
Dat external gate e85 torque. :)
^ What's done to it besides the SS2? Holy crap.
I'm running an SS2 with supporting mods, 275rwkw (370hp) on BP98, it's a capable unit. Specs here: http://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page-51#entry7370873
Would love E85 but the range sucks already on PULP and flex tunes are very pricey so it's a no go...
There is an ethanol servo on every corner in Melbourne, no excuse these days. :P
Just keep a jerry in the boot.
I managed to get 400k's from the little 40L tank in the evo the other week. No idea why the Stagea goes through twice that usually.
I would be incredibly happy with the power you're putting down from my car. I wouldn't want to go E85 for a while if I get that power.
I can't wait for my ATR45SAT to come ^_^
Some further updates. this is ATR45SAT internally gated on P98 fuel with fuel pump issue sorted. There might be an exhaust issue, car made 351rwkws with exhaust dropped before cat, and 305rwkws with the new 3 inches exhaust that just been made. Might be putting an screamer to the front pipe and see if that sort out the back pressure issue.
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
