head lifting because too much boost?
be a lazy prick like me and install ARP studs without pulling the head off! That 19 year old OEM headgasket loves it :)
  • Like 1
^^ Dodgy carnt...lol
you're forgetting I'm asian after all lol..
didn't you go to the darkside? why you still here? don't forget your turbo roots lol
sprayed more things black lol....
I might delete the charcoal canister and move the catch can there.. too much shit going across the engine bay at the moment :(
12108237_1139761716052956_84809291911063
Yeah that's not a bad idea, but removing the charcoal cannister and placing it there looks more tidy as well as defective lol.
On a side note, my dodgy install new studs and torque down the head band-aid solution worked.
Was at Wakefield all day today pumping 1.5 bar through the motor and no signs of pressure building up in the cooling system.. yay for 19 year old head gasket and motor haha
lol with a fuel pressure gauge and external gate on show you're fooling no-one about it being 'stock, officer' :P
good result on the no-head-off head stud job then, might have to look at that further myself.
Hey guys, I'm still tossing up between turbos for my build.
To be honest I just want the most responsive and snappy 300rwkw on E85 for the street.
I found a build thread where someone had made some very nice results on the highflow 21U turbo used on a R34.
There are a few options for me but I'm unsure.
SS1PU (I had one of these in my R33 for a few years and loved it, Stao has altered the build of these over the years and they seem to have gotten even better)
R34 Highflow (currently have the turbo so it would be cheap and easy to sort, but I'm unsure if it's going to be nice and responsive)
R33 Highflow (more responsive than the R34 highflow and I'm not sure where this sits between a SS1PU and the SS2 in terms of response and feel for street)
SS2 (stao said this is strong and powerful delivery)
I've looked at a fair few dyno sheets but still can't wrap my head around it all, can anyone lend some input
The SS2 should easily get 300 on e85, like very easily. I'm running 260kW on 18psi very safe tune. It has a bit of lag, but not much, full boost is about 3500 and it just picks up crazy ! I've heard the SS1 is a more responsive version, but makes less power. 300 would be pushing it with the stock turbos, but that's just my opinion.
Pretty much everything I listed there will net 300rwkw on E85, but which is going to be the most snappy and responsive.
Stao mentioned that the R33 turbo on a R34 would want to ping.
not on E85, I've found it just loses power rather than knock like 98RON, it might knock but not audible like 98RON (from my self tuning experience)
Interested to hear the answers to this.
Stay told me the same thing but I'm keen for ultimate response on the r34.
Someone on here got close to 300rwkw on an r34 with the 21u highflow, e85 and blitz return flow.
I'm wondering whether the e85 combats the pinging stao mentioned.
I don't want Lag so very keen to try and make the 21u work on the r34.
About to get some ID1000 to allow running of e85
I knew someone who made 310kw on 19-20 psi on e85 with the u21 highflow.. tbh it didn't feel very quick but the dyno sheet it had a very v8 looking power curve made full boost at like 3700 or something.. blitz front mount, xspurt 1000cc, pfc and hks exshaust
I guess it's a toss up between the SS1PU and the 21U then because the 21U has performed 300rwkw on E85 on fair few setups now. The SS1PU was a beast on my r33 and should easily make 300rwkw.
Stao, you're the man with the kowlwdge. Chuck us all some ideas :)
engineering a new ss2 at moment. should easily take over 300rwkws on pump. will up result shortly. ss1pu makes similar power then 21u but makes alot more torque. there is also a new turbine wheel on thd ss1pu this year, should up hp by 15kws with no lose in response.
  • Like 1
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
