What's different about the new SS2? Will it be keeping the same response? Mine is a late 2012 unit and I'm wondering whether it's time to send it to you for a refresh.
Also I'm running mine external gated (45mm hypergate) with a 25/30 neo setup. Made 265kw on 10psi and 292kw on 13.5psi.
Going for retune on Tuesday and upped gate spring to 14psi and will be running more boost now. Will post back with results ;)
^ oneday il be calling on you for guidance on how to build a 2530 neo, if wer following trend it should make more power with no loss in response.. i think thats what hes done across his range of turbos lately
engineering a new ss2 at moment. should easily take over 300rwkws on pump. will up result shortly. ss1pu makes similar power then 21u but makes alot more torque. there is also a new turbine wheel on thd ss1pu this year, should up hp by 15kws with no lose in response.
Still very much enjoying my 2013 SS2. If I ever decide to upgrade I'd definitely look into this low mount (or the ATR45SAT if it fits :) ), together with an external gate off the stock manifold.
I reckon the NEO might need some forgies at that point though...
Stao is it possible to modify a JJR bellmouth to work without an IWG or is it best to replace the dump/front when going ext gate?
Neo on forgies oh that would be alot of fun.
When i swapped over to external gate i had my bolton and acuator asembly sent back to stao and he sent the vband housing and then you just need to put a vband on your dump and get the gate housing made on the mani.. definitely worth doing!
  • Like 1
Nice!! So the exact same turbo but with ext gate? Would you have a dyno sheet before and after by any chance?
I have an ATR45SAT sitting at home now waiting to go in. I'll probably install it in the next week or so then it gets tuned around this time next month so I can tell you how it goes. Supposed to fit on the low mount stock manifold also.
Watch this space and I'll update you when It's done
  • Like 1
SS1PU will work fine it doesn't work with a small exhaust housing like the 21U units. So it will be fine.
The new SS2 uses a different exhaust side, on dyno, compare to the previous model, its been able to take more boost with more timing. I'll still still be aiming at 20psi by 3800RPM in 4th. For predicted end result it will be some where close to 340rwkws internally gated on pump 98 fuel and close to 400rwkws on E85 externally gated.
With the capacity of most common 3 inches diameter exhausts, I will be making some small bits and accessories to come around it.
With the capacity of most common intercooler and a 3 inches diameter exhaust, but I will be making some small bits and accessories to come around it.
Do you have a picture of the exhaust housing?
hory shet... makes me want to take out my SS2 and throw it in the bin and get the new version haha..
I'm pumping 24 psi into mine and the exhaust housing glows nice and red to only makeep 340kW. And by that time, my intake air temp is over 60 degrees lol
  • Like 1
ss1pu is for 1450 same as ss2. for a r34 because of the cams and higher engine comp, down low torque doesnt change alot between the two. I will be running an ss2 instead.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
