Hi Guys,
Is it better to run vacuum off the compressor housing to the boost controller or block that off and run it from the stock location in R33s (intercooler pipe?)
My ATR45SAT has it on the compressor housing and a friend with a similar turbo just blocked off his compressor housing one and ran as per above.
Thanks!
Thanks Dan, I read something similar just wanted to double check.
Another question - Does anyone know what size the studs are on the Hypergear ATR45 turbo dump side - I understand that most are actually bolts but there are two studs also.
I'm interested in how much to upgrade SS2 will cost, The new one sounds unreal and mine is due for a retune with E85 and new injectors when I can get all the parts together and on the car so the thought of upgrading turbo sounds good to me :)
the power bug, clearly we both have more than enough power but noooooo let's make more LOL
Haha.
Honestly, mine is probably about perfect for driving around town, which is pretty much all it does.
But now that we have E85 on pump, i know im going to make more power so may as well make a bit more on top of that :)
Haha.
I just want a little less lag as I track the car quite a bit at Wakefield (which is what I mainly use it for, does see the odd trip to the gym).
I find with the SS2 I need to drop it down to 2nd around certain bends, then bam I have too much torque/power and it's dori & smoke LOL.
However it's tits on the straight at Wakefield, I over take cars like no tomorrow haha.. here's a good clip of just that:
Hey Stao, when you get back just so you don't miss my question but will the SS1PU be more snappy and responsive than the SS2?
Plus more responsive than say the OP6?
yes that should be, and more responsive then a op6 high flow. but will be maxing towards 270rwkws mark.
looked like that 34 was slowing for the pits... lol :nyaanyaa:
my SS2 is lags, it's nothing nothing nothing then ALL IN like a rocket ship LOL
these days I drop it back into 2nd on that last turn to keep the revs above 4k
  • Like 4
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
