Hi Stao, would it be possible to high flow a op6 turbo with a smaller garrett gt35 68/62 84t turbine wheel and a ss billet compressor for better response than your standard op6 high flow?
I would like 260rwkw with boost before 3800rpm
on 98fuel with supporting mods thanks.
I can use the current turbine end using a SS2 comp wheel. that makes 20psi by 3800RPM.
so yeah, I'm after some more power... however what will be more responsive?
SS2 (current one, externally gated by scotty_nm35 last year)
OR
ATR45SAT ?
I do plan to get HAVOC fab to make me one of those stock manifolds with each pulse merged into a single gate.
^ dirty rb30 lol you know you want too.. :) i reckon his new ss2 sounds like it could be the better option but keen to see what tao thinks
nawwss man.. I like my stock 300000km+ Edward Lee's special edition with 149000 km the dash motor :)
Well I want to push the limits of this motor and see what happens, if it pops.. oh wells RB30 it is lol
  • Like 1
Is there any graph comparing the t67 you do with the new ss2 have a t67 looking for some more midrange looking for
300 on 98 on less the 20 psi
And
Would op6 high flow be too small for a standardish dirty thirty with 25 head?
Mid-high range is good enough for me from the op6 high flow on rb25 and I can even live with how it performs on the lower rpms, but more bottom end torque is always a good thing
Below is correct:
So response wise
Ss1pu>old ss2>op6 high flow?
Search page 1. There are few readings.
The Current ATR45SAT makes way more power that also had about 250RPM better in response.
The new SS2 will do similar with about 200RPM better response to ATR45SAT.
Both of them will do 300rwkws on P98 fuel internally / externally gated at 20psi.
any idea on when we can expect results for the new ss2, and when its available?
my turbo is dead and looking to replace it, wondering whether i should wait for this newer one or just get the current one
The new SS2 is shares the same turbine size as an ATR45SAT model. The very old SS2 and G3 made around 2009 ~ 2012 might work in terms of high flowing, but not the mid 2012~2015 July models, how ever I can offer a discount for people whom wish to upgrade.
This is a high flowed 2011 model ATR43G3 into an ATR45SAT, running an 38mm gate off turbine housing. Car made 492rwhp on 20psi E85 fuel:
Don't have a very clear copy yet. I will upload when I have it. Pretty fat curve for now:
  • Like 1
Isn't the atr45sat built in a op6 rear(or your own .64 rears) , not .82 ?, so are ss2's in .64 rears now aswell?
Does the ss2 comp wheel fit in a r33/34 nissan comp cover?
cheers
darren
Edited by jet_r31
The Nissan OP6 Rear housing doesn't have enough materials on it for that exhaust wheel. Its going to break a large chunk out of the side, I will then need to make up a patch and weld it back in place. eg:
The amount time spend on it didn't worth the housing plus the latest exhaust wheel is larger then above.
Nissan comp housing is too small for the new wheel, it worn the cold side collar during few high boost evaluations earlier. The T04 .50 comp housing worked best.
  • Like 1
One more announcement to make I wish to make, is my workshop is now opening to public. We will be carrying out all sort of engineering service to every one whom needs any sort of turbocharger related work for very reasonable prices, and for 9 years of turbo related engineering experiences, you will not find better workmanship. So If you wish to build you own dream turbo your own way, here is where you start.
Here are some prices for some basic services. I will keep the list updated.
Individual component balancing for compressor and turbine wheel or Assembly balancing: $100
VSR simulation and corrections, this is ideal for checkup for used and brand new CHRAs.
Turbocharger Compressor profile and machining to suit specific compressor wheel and back plate $150:
Turbine housing profile and machining $150:
Turbocharger Wastgate porting and machining $50
This is a engineering service re-shaping turbocharger back plates to suit different radius and height of given compressor wheel and housings. The cost for this service is $50
This is a compressor wheel re-bore and re-size service. Our tolerance to perform this operation is under half a thou (1/80 of a mm). This service is perticular useful when people wish to mix and match compressor wheels in between different turbocharger manufactures. Ie. GTX Comp to TD06 Turbine.
The cost to re-bore is $50 and cost to re-size is $50 Per phase (Can be taken from top or top and bottom depending on the length of the turbine shaft and bearing housing used.
  • Like 6
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
