My latest dyno run:
After adding in an addition 6 degrees of timing up top and about 4 in between 3900rpm and 5400 rpm the motor refused to make any more power. Ended up making 327kW but I was leaning too much on the timing so scaled it back and she made 325kW E61
If anyone is interested in the logs, I'll e-mail them to you.. can't seem to attach CSV files.
And here's a short video of 3x cars I tuned that morning (including touching up my own, ignore the AFR readout on the S15 as it runs blast pipes)
Hey Stao, how is the new version of the SS2 different, and how much time/cost would it take to upgrade mine to the new spec (If possible)?
I'm hoping I can keep the turbine housing as mine is modded for the external gate, if its too much of a hassle I'm more then happy with the way it performs now, more just curious about details on upgrading
is that petrol AFR or E85 setting ?
E61, wasn't planning to put it on the dyno but I had some hire time left so pumped the 98 tank with E85
Some updates. This is from our High flowed 21U R33 turbocharger. It is currently a prototype.
It is currently fitted to my R34GTT, car made 287rwkws @ 20psi, full boost in 3500RPM. P98 fuel.
  • Like 1
How do you expect this latest high flow prototype to compare (in total power and response) to a HKS GTRS turbo?
The GT3071 version? probably similar
On paper this is about the same as an SS1PU. stock manifolds, internally gated. P98 fuel
I love the response of the GTRS ~ With my setup I have 5 lb at 2000 rpm and full boost at 3k.
But I realise the technology is getting a little old now. I'm wondering if there is a billet wheel turbo that has the same response but will give more power through the rev range.
Car got tuned - Tuner wasn't very happy with the IWG/Actuator so I'll PM Stao about this later. Tuner said he can get a wastegate performance graph for me to send over.
With that said I'm very happy with the turbo and the power, comes on well holds you back in the seat drives great.
5295311E-1770-4210-9BE2-8E9CF17A231F_zps
Edited by kingtube69
I reckon drop the cat and re run the car, there's probably some restriction in the system.
When I modded my cat back and introduced a resonator and a mid muffler (both straight through) I noticed a slight drop in response. Even on the dyno it a few weeks back I noticed a slight drop in response coming onto boost, even though I loaded it up at 3k rpm before starting the run.
Going to redo the turbo back when I redo the turbo setup.
  • Like 1
that car is running return flow cooler. He actually made within 1kw of my result when I did return flow evaluations. Drop exhaust and PWR cooler it should be sitting around 330rwkws mark.
Thanks all (Stao included) It goes for a retune early next year for e85 so I'll get it looked at then. What are the options for a more free flow exhaust? Would decat see some gains? Does anyone know how PWR compares to Plazmaman?
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
