Sir Lord Van Von Vader'ham Posted March 28, 2023 Share Posted March 28, 2023 Thanks mate, thats exactly the info im after. It is a 25. i will go ahead with the original plan then but a g3 then how does a G3 compare to SS2? im not sure what the name of the profile actually mean. as you said its a little confusing on the site. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7977478 Share on other sites More sharing options...
GTSBoy Posted March 28, 2023 Share Posted March 28, 2023 Contact Tao and ask. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7977481 Share on other sites More sharing options...
Komdotkom Posted March 28, 2023 Share Posted March 28, 2023 I've got a new 21U highflow if you are interested. Tao did some secret squirrel shit to it about 5 years ago then I never used it. Made 280kw on an RB25 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7977488 Share on other sites More sharing options...
hypergear Posted March 28, 2023 Author Share Posted March 28, 2023 5 hours ago, Sir Lord Van Von Vader'ham said: Thanks mate, thats exactly the info im after. It is a 25. i will go ahead with the original plan then but a g3 then how does a G3 compare to SS2? im not sure what the name of the profile actually mean. as you said its a little confusing on the site. ATR43SS2 is a brand new turbo that is capable of making more power. Ball bearing option is highly recommended. It is also highly recommended working with our externally gated turbine housing kit. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7977493 Share on other sites More sharing options...
hypergear Posted April 1, 2023 Author Share Posted April 1, 2023 (edited) Regarding to Rb20det highflows or builds from earlier discussion, they runs a smaller turbine and and compressor then a RB25det turbos. Can build it into a OP6 it would work similar to a HKS2530 with a modern wheel set for more power. Its not a bad choice. Sharing another result. This is an ATR43SS2 on Pump 98 fuel making a pretty responsive 355rwkws @ 20psi. R34 GTT Rb25det Neo standard engine ARP head studs HyperGear ATR43SS-2 ball bearing turbocharger 6 boost high mount exhaust manifold 50mm external gate 4 inches intake pipe 600x300x71mm front mount intercooler 3.5 inches turbo back exhaust 1000cc ID injectors Haltec ECU Tuned by Chequered tuning Melbourne Final result of 355rwkws on pump 98 fuel / Ron 93 at 20psi, hitting 220rwkws @ 4000RPM. Edited April 1, 2023 by hypergear 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7977722 Share on other sites More sharing options...
hypergear Posted May 24, 2023 Author Share Posted May 24, 2023 Sharing a pretty interesting result from a Rb20DET with Rb25det Neo Vct cams. Turbo's one of our ATR43-G2 BB model for RB20det in T3 .63 rear housing. Car managed to pull a pretty responsive 321rwkws on E85 fuel externally gated. Engine's in a Ford AU . Pretty interesting eposide to watch: Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7979828 Share on other sites More sharing options...
hypergear Posted June 3, 2023 Author Share Posted June 3, 2023 Updating result from latest model ATR43SS-3 Turbocharger: Keepitreet R33 GTST 4 door Rb25det Neo engine Forged pistons and con-rod Ross performance trigger kit 1650cc Bosch fuel injectors Two 460L fuel pumps Adaptronic plugin ECU Upgraded Valve springs Hypergear ATR43SS-3 Turbocharger 6 boost high mount TS exhaust manifold Twin turbosmart 50mm external gates Tuned at Chequeredtuning Victoria Car made a final result of 482rwkws @ 24psi. Hitting 280rwkws @ 4000RPM with wide spread of power band and plenty of area under curve. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7980150 Share on other sites More sharing options...
hypergear Posted June 20, 2023 Author Share Posted June 20, 2023 Updating this thread as some of yous would have seen on FB. Not about turbos this time, but a piece of information for people seeking the Rb2530det rout. I've attached results of my built Rb25det with Kelford cams Vs my built Rb30det with HKS cams, making it a reasonable comparison of what Rb25det Vs Rb30det is like. Both engines had identical setups, E85 fuel, made the same power, while the Rb30det was 1300RPM better in response, more power every where and 137Mn of extra torque. I’ve also attached result of differences HKS cams made in comparison to stock Rb25det cams on the Rb2530det engine. 6 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7980544 Share on other sites More sharing options...
soviet_merlin Posted June 20, 2023 Share Posted June 20, 2023 7 hours ago, hypergear said: Updating this thread as some of yous would have seen on FB. Not about turbos this time, but a piece of information for people seeking the Rb2530det rout. Thank you for posting here as well Tao! I'm not following social media so I very much appreciate it. Though in some ways I'm not sure if it is good that you keep posting these promising results You are the voice of temptation. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7980546 Share on other sites More sharing options...
hypergear Posted July 5, 2023 Author Share Posted July 5, 2023 Sharing a pretty good Pump 98 result: R33 GTST forged rb25et engine Standard head and cams ARP head studs Supertech valve springs kit HyperGear ATR43SS-2 ball bearing turbocharger 6 boost high mount exhaust manifold 50mm external gate 4 inches intake pipe 600x300x71mm front mount intercooler 3.5 inches turbo back exhaust 1000cc ID injectors Link ECU Final result of 372rwkws at 25psi. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7981058 Share on other sites More sharing options...
hypergear Posted July 6, 2023 Author Share Posted July 6, 2023 (edited) Update on my Rb2530det R33 GTST project, Now sitting at 497rwkws. Engine Specs: Rb25det head with forged Rb30det bottom Forged pistons and con-rod Upgraded Valve springs HKS step 1, 256/ 264 drop in cams Fuel system: 1650cc Bosch fuel injectors Two 460L fuel pumps ECU: Haltech ECU Turbo side: Hypergear ATR43SS-3 ProR Turbocharger 6 boost high mount TS exhaust manifold Turbosmart 50mm external gates Hub Dyno Tune: Chequeredtuning Victoria Car made a responsive 497rwkws @ 25psi full boost by 3500RPM. Hitting 150rwkws @ 3000RPM and 340rwkws @ 4000RPM, with wide spread of power band and plenty of area under curve. Edited July 6, 2023 by hypergear Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7981091 Share on other sites More sharing options...
hypergear Posted July 24, 2023 Author Share Posted July 24, 2023 Updating result: R33’s back at Chequered tuning for with another of my in-house built specials. Car had no other changes apart from the turbocharger, we managed to get: 516rwkws @ 26psi 569rwkws @ 29psi 606rwkws @ 30psi 642rwkws @ 34psi Turbo’s holding boost with pretty consistent gain per additional PSI of pressure is added. Unfortunately my 3 bars Haltech Map sensor (vacuum is a bar) was very maxed, be back on the dyno to max out this turbo once new sensor arrives. Pretty successful day over all. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7981429 Share on other sites More sharing options...
hypergear Posted August 27, 2023 Author Share Posted August 27, 2023 R33's back on the dyno again for development work, testing an new 6 blade 55mm prototype turbine. Using ATR43SS3ProR turbo for back to back test. New turbine shown a slightly laggier curve, but picked up 16kws on same boost pressure with smoother mid / top range power and torque band. Final run of 509 rwkws @ 25psi Engine Specs: Rb25det head with forged Rb30det bottom Forged pistons and con-rod Upgraded Valve springs HKS step 1, 256/ 264 drop in cams Fuel system: 1650cc Bosch fuel injectors Two 460L fuel pumps ECU: Haltech ECU Turbo side: Hypergear ATR43SS-3 ProR Turbocharger 6 boost high mount exhaust manifold Turbosmart 50mm external gates Hub Dyno Tune: Chequeredtuning Victoria 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7982229 Share on other sites More sharing options...
Dose Pipe Sutututu Posted August 27, 2023 Share Posted August 27, 2023 What RB wet dreams are made of, comes on super early and makes a great amount of power. Would be an excellent powerband for a circuit car. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7982230 Share on other sites More sharing options...
hypergear Posted September 8, 2023 Author Share Posted September 8, 2023 Updating result, This is from our latest ATR45SS-3 model, Its made for 100bhp applications. Same car as above. It managed to pull 636rwkws at 34psi. Drive ability wise, car hits 300rwkws by 4K and 450rwkws with 1014Mn of torque by 4250 RPM. Pretty good to drive with crazy amount of mid range torque. Run against ATR43SS-3ProR turbo from earlier. r33636rwkwsmusic2good1min.mp4 3 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7982659 Share on other sites More sharing options...
Desean Strickland Posted September 11, 2023 Share Posted September 11, 2023 hey guys so i wana make 250-260kw atw on my rb25det, would the g2 be capable of making that power goal or do i need the g3? just kinda confused because on the site it says its capable of 350hp but doesn't say if its meant for an rb20 or if its suitable to make 350 on an rb25. ill be running 550cc side feeds, a walbro 460, frontmount IC and all the other stuff necessary cheers Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7982731 Share on other sites More sharing options...
GTSBoy Posted September 11, 2023 Share Posted September 11, 2023 G3 is the default profile for RB25. You wouldn't likely choose G2 for it. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7982734 Share on other sites More sharing options...
hypergear Posted September 12, 2023 Author Share Posted September 12, 2023 21 hours ago, Desean Strickland said: hey guys so i wana make 250-260kw atw on my rb25det, would the g2 be capable of making that power goal or do i need the g3? just kinda confused because on the site it says its capable of 350hp but doesn't say if its meant for an rb20 or if its suitable to make 350 on an rb25. ill be running 550cc side feeds, a walbro 460, frontmount IC and all the other stuff necessary cheers Hi, G3 profile with Rb25det turbo housings will be fine for around 270rwkws on Pump 98 fuel internally gated. I can supply donor housings if interested. To make the power you will need 3 inches metal induction pipe, 600x300x100mm front mount cooler, at least 3 inches turbo back exhaust, programmable ecu, along with injectors, fuel pump, you've got. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7982772 Share on other sites More sharing options...
33GTRV Posted September 24, 2023 Share Posted September 24, 2023 Stao, Just managed to get my hands on a GTI-R pulsar. I want a snappy 400 awhp, on stock stroke. Will do camshafts if required. What do you recommend? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7983128 Share on other sites More sharing options...
hypergear Posted September 26, 2023 Author Share Posted September 26, 2023 On 24/09/2023 at 12:06 PM, 33GTRV said: Stao, Just managed to get my hands on a GTI-R pulsar. I want a snappy 400 awhp, on stock stroke. Will do camshafts if required. What do you recommend? Hi, on E85 fuel and internal gate, 54mm ATR28SS15 in T2 .64 rear housing will do nicely. I've used BC Step 2 (272dur /12mm) on SR20det for 300rwkws+ applications 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/621/#findComment-7983222 Share on other sites More sharing options...
