It was a joke :) He is a good mate and knows me well enough to know that if we popped the motor from silly boost I wouldn't blame him. I don't think he would be like that with his normal customers :pirate:
If it is tuned safely and correctly what chances are there of you popping a stock 25 making 260-70kw anyway? Keep it rich and nice and cool, safe on timing so it doesn't ever det, surely the pistons aren't going to melt if you keep the AFRs down?
What are peoples thoughts on making this power on the street? I realise on the track where you are WOT for 75% of the time it could be an issue due to excessive temps, but on the street?
The G2 is only a small turbo. Also Its more of the factory exhaust manifold restricting flow so the power figure is well kept around / under 300rwkws mark. Probably not worth investing a turbo that pushes beyond that unless its going to on a high mount ext gated setup, and I'm pretty sure all the current ATR43G3s has no issues making 340rwkws+ on it.
I'm considering of going for a high mount manifold with ext gate once there are nothing left to improve using factory setup. How ever that will not reflect the power figure of those without the same setup.
Once you finish developement on your stock lowmount stuff you should definitely look into a turbo suitable to an off the shelf 6boost manifold and use a Tial MVR gate.
This is the staple setup for those T67 setups, if you want to get into non stock position that is the item to beat. You will need to work hard because the price is insane :nyaanyaa:
Its actually cheaper making the T67 alike setup as there is not need spending timing in making all those bolton adaptors as well as internal gate setup. Like we only charge $1000 for the internal gated ATR43G3 units.
6boost do a low mount setup, i tuned one with a t67 and came up great... 340 @ 19psi
I know man but if your going to optimise the G3 for a high mount you no longer need all that bolt on crap. Either a simple generic 5 bolt rear or a v band external gate, should bring production cost down.
Fitting the pu 1.5 in the morning. Just going to be road tuned till the injectors arrive. Let ya'll know how it goes :D
Looking forward to it and really curious to see you opinion on this turbo in terms of driveability and power compared to other turbos you've tested :)
Thats one busy looking exhaust side, how do they compair flow wise to the high mount?
identical, high mount is only to package things easy, turbo placement has no bearing on results.
By the way this turbo on the test car is for sale with a discount. PM me if you are interested.
This is a hill climb competition footage sent in from one of our customer's S14 using ATR28G3 (268rwkws from memory) in Switzerland. enjoy
:nyaanyaa: No its not a S14 SR20det. Still a G3 turbo, but on another mighty CA18det 180sx with 310rwkws. He's on NS now.
Ok pu 1.5 has been installed. Not going to go into detail about the install just yet but a few things had to be modified.
Havent touched the tune yet as customer had to head to sydney. Went for a quick road test not exceeding half throttle and so far very impressed with the near stock response.
This turbo has a very unique and nice sounding spool up.
Will be doing a quic road tune today just to set AFR's then hopefully get on dyno next saturday or possibly during the week.
Im excited for the results
Little update:
This is a from a scrapped blown Ford XR6 turbo that we've rebuilt from scratch with a ATR45 core. Its fitted back on to a Auto XR6 (edit: NA+T) 4L with 3500 convert. Car made 295.5rwkws on 11psi with Caltex E65.
Looking back from where we first started, my dynosheet pile is about the same height as a Nissan skyline engine manual :w00t: and it will keep on getting thicker.
Any way, ATR43G3 is back on the drawing board for the 4th time, I'm hopping of gain better response while not losing the consistency, top end power or peek torque.
Tao that XR6 was a NA+t AU ford with std high comp engine.
Really? AU's didn't come with turbo's so was the turbo from another XR6 car? Or was the car a BA XR6 turbo?
Why would you do it?? Maybe not the same kettle of fish, but my standard NA EL Fairmont feels like its almost got too much power for its chassis :yucky:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
