So i have come accross a cheap RB20 NEO from an R34. I understand its a whole 140hp of 2L goodness and was the most economical engine in the R34 range. But thats all i can find out on them? Does anyone else know much about them?
Looking at the timing belt cover there is a pronounsed bulge, so i am thinking it has variable inlet cam like the RB25s. I want to see if anyone knows anything of them before i buy it...but i am hoping it has a better head and possibly uses solid lifters and may accept RB25 Neo cams etc.
https://www.sau.com.au/forums/topic/268302-rb20-neo/
Might be worth contacting Brad from spool imports. I believe he had a rb20 neo head for sale a while back and from what I could tell I think they have solid lifters and also run an inlet butterfly setup similar to the redtop rb20's.
Spool Imports
Edited by HR31_RB20DET
https://www.sau.com.au/forums/topic/268302-rb20-neo/#findComment-4572516
  • 3 years later...
The 20Neo is obviously a far better engine than the old 20. It has everything that is good about the 25Neo......but it is missing 500cc. Same as the old RB20s. Makes one wonder why one would bother buying one and doing the work to install it in something when there is a 2.5L version available.
https://www.sau.com.au/forums/topic/268302-rb20-neo/#findComment-6646533
I can't think of a reason to keep any car's engine capacity to 2L where it would make more sense to use an RB20 than a 4 cylinder like an SR20. Any Skyline can be legally embiggened to 2.5L without pain. Anything smaller car that can't go above 2L capacity would not be a good thing with a heavy lump of cast iron 6 cylinder in the front.
https://www.sau.com.au/forums/topic/268302-rb20-neo/#findComment-6646857
Yeah, agreed here...kinda makes more sense in any situation to go SR20 over RB20
https://www.sau.com.au/forums/topic/268302-rb20-neo/#findComment-6647766
It definitely makes more sense to use the SR20... as long as you dont mind driving around with ear muffs on to hide how crappy they sound :P
https://www.sau.com.au/forums/topic/268302-rb20-neo/#findComment-6648391
Someone somewhere must know the exact differences with late RB20's . Variable cam timing and a shim type valve train would be worth having .
I'd also be looking at chamber shape and size because they changed on the Neo 25 - possibly be cause of emissions and detonation reasons .
How do the CR and power output compare R32 to R34 RB20s ?
Is there an engine manual available that covers all the R34 era RBs ?
A .
https://www.sau.com.au/forums/topic/268302-rb20-neo/#findComment-6650104
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
