I went tyre testing at Lakeside last Sunday. Dont mind these KU36 things as a crossover road and occasional track thing. Excellent value.
Not a fantastic race tyre but good for 1:02 on the day.
Edited by Noddy
yep, I loved the KU36. Great bang for buck, and awesome fun. You had to slide them around a bit to get the times out of them. :) 60 seconds on my old Supra with Tein Flex, pod, and catback.
Yeah its a good fun little track. Next time out we are doing the F8 layout which will be a nice mix up.
The car is getting there. I basically spent that whole day making set-up changes and in the end it was much improved after some ride height adjustemnts. We have made a couple of other small changes this week and am back out testing this weekend at Sandown so I will see what difference we have made given I have a base time at this track in this car already from back when it was poo. LOL
Here's a little vid of me in an M3 under controlled conditions. Once a year BMW take all the Master Parts Advisers and Service Master Tech's away for a weekend of fun. This year was E/C,,,we did track work,,,khana's,,,abs testing and go-karts. Oh and free food and lots of piss.
This vid was made using an apple 4,,,handheld by my passenger,,,excellent quality.
Jeff Brabham is the head driver trainer,,,great guy with tons of info.
Cheers
Neil.
From the autocross yesterday. Its a short, smooth dirt circuit. Awesome fun!
2nd run of the day - messing around with what gear to be in throught he middle of the track. 6th outright on this run, surprisingly!
And the first run in the reverse direction
just on normal street tyres. they don't allow rally tyres (or anything nobby)
the fast/serious guys use semi slicks becaus ethe track ends up being really hard packed and rubbered up like a speedway track after a couple of runs. hearing tyres squeal on dirt is strange...
freakin awesome harry ! looks like a workout with lots of steering work, like a sprintcar! was the car ok after hammering over bumps?
racing at LS on the weekend was a new experience. the field was small due to the way they organised the classes, so we got lumped in with formula fords for the first couple of races! wtf.
There were plenty of similar cars that got spread out amongst the other classes. strange.
pretty intense to actually have to push 100% for the full 5 laps, not just against yourself/the clock.
Perfect laps were not as easy to achieve compared with a sprint session and being alone with clear track.
Edited by scooby36
That track isn't bumpy - plenty of people take lowered road cars there. Worst damage you'll get is hitting a witches hat at speed.
Handbrake - GCTMC run similar races at Pimpama down the Gold Coast(Yawalpah rd nursery) which is a bit rougher, but still a lot of road cars enter. Also, they run a khana cross at PArklands showgrounds, but I've never driven there so don't know what the track is like. The only others I know are fairly bumpy and not really suited to "nice" road cars. Hirstglen has a fantastic layout, but it's more like a proper rally stages (ie be prepared to get some air). Unfortunately the track washed away in the floods in January, so it will likely be a long time before the track is useable again, and the local council is giving the land owners a hard time about using it fio motorsport.
I did a khanacross at Parklands about 10 years ago. It was a little rough in places. I wouldn't recommend that for a road car.
The IWMAC Autocross is smoother than that horrible racetrack that's right next door - QR! No problem at all for my car which is really setup for track - reasonably low, not much travel with the Tein coilovers and 7/6kg springs. Only needs a good clean out in the wheelarches!
Morgan Park started life as a dirt short circuit before it evolved into what it is now. And Carnell at Stanthorpe used to be a dirt short circuit as well I think, but has been bitumen for the whole time I've known it. The IWMAC Autocross track is the last of the maintained dirt circuit as far as I know. There was talk years ago of sealing it too, but I'm glad they didn't because its pretty unique the way it is.
Scooby - congrats on the racing debut! And good work keeping up with Tony's RX7, its obviously far more powerful and he also runs full slicks. Would have been pretty hairy racing against FF's! Would be bloody hard to see them alongside you in a car. CAMS would never run open wheelers against tin-tops.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
