hmmm... graphed speed and lateral G from the 180 on Thursday and Aristo yesterday:
(lateral G x50 to get it to show up on the graph, so 50 is 1G. Peak for both cars is 1.2G
It wasn't the fastest lap int he 180SX - the iPhone didn't want to stay on the windscreen inthe 180, so I've only got data from the 1st session. This lap was a 60.5.
The automatic Aristo looses out in accelleration, but it looks like it was at least a match for the 180 in Eastern Loop and the last turn, if not a touch faster... Caught the 180 a bit under the bridge too. I suspect I lifted on that lap in the 180, or it got a bit sideways and scrubbed the speed off.
Aristo felt much easier to drive through Carousell, under the bridge and through the kink. Carousell's double apexer, the Aristo just goes where you want it to, no fuss at all. The 180 is always puts up a fight to get it back into the second apex. In the fast corners under the bridge and the kink, the 180 is pretty nervous on the bumps. Aristo walked over them with no fuss at all. Might be interesting with a bit more boost in the Aristo and maybe without the heavy electric seats! hehe
Hey, what app are you using to produce these graphs? I think you were using an iPhone?
very interesting. it looks like the 180 gets it's power down very well or just has a more punch set-up (I guess the manual vs auto would help too out of corners) as it gets a big speed advantage out of corners which it then maintains up through the gears. the aristo doesn't seem to give much away though in outright top speed and I guess peak G is not too surprising given both on the same tyres. it's interesting sometimes how quick a near standard car can go. makes you wonder how many of the mods we do are sending us backwards not fowards. there is a lot to be said for small improvements on factory engineering not wholesale changes. good steering too. :)
Baskerville May 15th 2011
nice vid mate! nice driving too. That blue datto(?) sure had some grunt in a straight line. your thing looked great underbrakes and well balanced through the 3rd gear stuff but he had some serious tow down those straights and quicker stuff but then it looked like he ran out of tyre grip (or maybe concentration) towards then end and couldn't keep you behind anymore. looks like you picked up a bit of pace once past him too. car sounds great and looked nicely set-up too. well done. :)
You're right on both counts - its getting power down better with the FZ201 than it did with either the R888 or the Kumho slicks, And it's a pretty punchy setup - not hugely powerful, but good strong midrange
got to say I'm a bit surprised the big Aristo can get the same lateral G from those tyres despite 300kg more weight to lug around. But I don't think I was driving the 180 particularly hard enough on that run though. Let's see what I can get out of it this weekend...
Edited by hrd-hr30
yeah well you did already say you weren't 100% feeling at home in the 180 after half a year out of it. still very impressive stuff for the aristo, like you said lots more weight, but with softer set-up, more body roll etc it probably hangs on pretty well. and I'm guessing the big 2J has similar power to the 180? around 280hp atw? I imagine with a manual box it would get close to hanging with the 180 out of corners too.
makes me wonder sometimes why we bother with all the stuff we do to cars which makes the NVH through the roof, makes them stiff as buggery etc. makes them look more impressive to drive I guess!! lol.
Mark, thanks for posting. You're absolutely flying! S13 represent :)
Are you taking turn two and nine in 3rd gear? Is that to make the throttle control easier on corner exit? Have you found it faster than doing them in 2nd?
Cheers mate. S13's rule! Spot on with the gears. I never use anything lower than 3rd gear. Same at Wakefield too.
The car has good low down response thanks to the small disco turbo, it is faster using 3rd gear for me.
4.3 ratio diff helps
that's seriously stripped out Mark. very nice time!
what diff have you got? hard to really say in the vid but it sounds a little loose/open out of a couple of corners?
Thanks Harry! It's not too stripped, still lots to go. It weighs 1082kg without me in it. It sounds loud/good (I think) due to the side exhaust I'm running.
You're correct with the diff, nice pick up! Stock viscous lsd. It's starting to open wheel and costing me a little time on exit of corners.
I need to shim it and get better drive/power down. Only recently has it started to loosen up.
I set a PB in the session after that vid with a 1:44.19, finding a further 2 tenths of a second from driving better.
It's amazing when you think you found the limit, then you go abit quicker. I hope to go a little quicker next time so maybe 1:43's are on the cards next time.
Edited by nismoman
Thanks Ben. Much improvement needed but I was happy for an initial test. Was great to be at a familiar track which made me feel more comfortable in the car, and gave me the chance to just concentrate on getting to know it. It was very well behaved, and once we can sort some of the understeer in the slow speed stuff it should be even better.
The bird made things interesting. I spotted it and backed off momentarily, made the heart skip a beat!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
