  • Replies 121
As in, on the street, you're not likely to see boost, unless you wind it up in 2 - 3 gears first.
however you are most likely to find small birds in your engine bay..
we really need pics of you naked to help...
:P
have you ever driven a turbo car? since your NA and all...
and i believe a fence post jumped out in front of you before, well even with a standard turbo that fence post will be lodged in your front bar allot quicker.
sorry to be harsh, but you have to think logically, best option as someone else said neo turbo motor dropped in and leave it and learn to drive it.
Edited by 32_Dave
Frank answer... yes that turbo will do the job, you already know that tho, you can look up the rating on a turbo anywhere,
Is your engine at that turbo a good package to use to do the job? No, its dumb, nothing personal, no "your a girl and dont know better" just from one skyline owner to another.
Using an NA package and converting it to turbo and then going for big power is really just an exercise in spending. anythings possible if you spend enough on it.
BUT, it wont be reliable.
Better compromise, get a 25det neo engine and drop that in, use that as a base, you'll still have issues and spend lots, but you might spend a little less in the long run.
If, like climbing a mountain, your doing it "cos i can" then dont ask... just do it... spend the cash, the time and live with the results. you'll get your power for some period of time.... then you'll do something else.
Now think, other that "Huzzah!!! i gots powah!!!" what are you really hoping to acheive?
I agree with what everyone is saying, I think you should look at dropping in a neo turbo engine to begin with. I think the power level your chasing from the get go is unreasonable, not because its unacheivable but because there are so many things to factor into the build rather than "Im building a show car and I want this much power" There are plenty of insane cars out there running less power than this, plenty of show cars out there running less power than this and it seems that all your chasing is the "aw factor".
Also try to do some research on cars that use the t51r, I believe the godzilla motorsports 32 GTR runs the t51r SPL, research some 34 GTT's that are making good power. You will get more satisfaction from a gt2835 or hi flow on the street than you will t51r.
If I was in your position, building a fast streeter id be going hi mount 35 series turbo, but thats just me.
She's not building a streeter, she's building a show pony. Nothing more, nothing less.
Oh, and MISSR34 did you ever find your missing KWs that your knock sensors were supposedly hiding... With your PFC and all that doesn't do anythign with the knock reading other then flash a light...
See, we'll let that be lesson one for all the boys here.
She WON'T listen to you, no matter what you tell her. Supposedly knock sensors caused her to be majorly down on power, whilst she ran a PFC... Oh, and she argued black and blue they were the fault... :ninja:
Since your engine builder has suggested that turbo - use it. If you dont have faith in your engine builder - go somewhere else and use whatever turbo they suggest. If you dont follow your engine builders advice they have an out if there's a problem, and there's more likely to be a problem as other stuff like headwork, cams etc will be selected to work well together. Throwing a random, potentially missmatched piece of kit into the mix is not a good approach.
knock sensors deff can make you down on power, if the tuner is using them, and backs the tune off early...
dont bother with a neo motror, you'll need a full rebuild for 500rwkw either way, so why spend the extra coin on bits you'll be replacing anyway
did you make a thread like 2-3 weeks ago about making your N/A supercharged?
Oh yeah, i remember her, i read that whole thread then it disappeared and I wondered what happened,,,all i can say is the determination she is showing far outweighs her rational thinking. Sure, if you got the money to spend and have absolutely NOTHING better to spend your money on,, then go ahead, good luck and godspeed
You should really add what you want to know about the T51R. From your post you aren't worried about spool etc, so thats good as there won't be much - and you want >500kw which is what a T51R will do fine as well.
What is it you DO need to know about it? It might help you get some more constructive responses - especially if you give some input on what your intended engine build spec is, you are still using the 25 block? Fully forged etc? What fuel will you be dyno queening on?
ill be going RB25 top end with RB30 bottom end to help with torque.
yes it will be fully forged and ill be having custom cams made up aswell (the cost the same as buying ones of the shelf).
ill most likely to be using Martini Racing Fuel for dyno comps
if ive found the right information, the Garrett GT4594R is basically the same as the HKS T51R, so ill be going with the Garrett one. I just thought maybe some people on here have used that turbo, or know some more information about it? just in a general sense really.
i have my list of everything that i need to get (im always adding to it as i go tho). But cause i pretty much know SFA about turbos, and im willing to admit it, id just like a little help, but like you said i prob should have made it a bit clearer to begin with.
do you have a boyfriend?
what does he say about your endevours for a 500kw car??
cos i'd be seriously pissed if my girlfriend wanted to waste that much money on a car for a few minutes of fun on a dyno at a car show, cos honestly, it seems that a car with over 300rwkw on the road is pretty useless and to only really use the power on a dyno or on a track really wouldnt be worth the money.
try fooling around in bed, much more fun than sitting in a car on a dyno pulling over 500kw
just my two cents
unlike yourself, id get more satisfaction sitting in a 500rwkw Skyline than what a guy could ever do for me :D and no, im not a lesbian.
and no, i dont have a boyfriend. and if i did, its love me, love my car or get F***d.!
agreed - a proper plan which is based around the 500kw u want is a good idea,
as apposed to just chucking expensive parts together willie-nillie which has the potential to leave you out of pocket, and unsatisfied..
you need to get laid.
:D
Guest
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
