Just to get this straight.
How much am I looking at spending to get a regular BA Falcon into safe, reliable towing condition? I'll need:
A heavy duty tow bar (how common are these on Falcons, can I find them easily or am I better finding a good BA and attaching one?)
Transmission cooler.
Rear springs.
Decent pads. ~$500
I'm guessing the first two are required, whereas the last two are more for safety and peace of mind. Any idea how much these items would cost?
Cheers.
Im sure you could get a PWR transmission cooler kit for around $165, maybe a bit more? plus fitting obviously.
A set of helper springs is no more than $180
HD tow bar is ~$6-700 (depending on hitch or tongue)
Load Leveling kit is anywhere up to $1000 (all depends on ball weight and specific kit etc)
sway is mainly caused by insuffient ball weight versus total weight of the trailer. When towing with a normal car, they often have low ball weight limits. And if you load them up properly, the arse of the car is dragging on the ground. So you end up with people putting the car further back on the trailer to take weight off the tow car's rear axle. Inssuficient ball weight is the result and sway becomes a real risk on rough or uneven roads, crosswinds, passing trucks, sudden manouvers etc
anyone used a au falcon ute auto for towing a 33 gtst?
I use mine all day everyday to tow both car/trailer and all my work gear with no dramas. Pulls like a dream and better than my old VY that I used to use and being t-bar auto have room for 3 which is handy.
I've got upgraded suspension & brakes, aftermarket headers and exhaust, cam and CAI all thanks to Jim Mock which doesn't hurt either :D
  • 2 months later...
Not much chop for anything more than a box trailer.
I just picked up my new tow vehicle the other day - got a Ti Pathfinder (not the 550 though - that would cost me nearly $20k more than I paid for this one). Haven't towed with it yet, but at least the kids are kept happy with the rear DVD player now. I don't like that they've deleted the telescopic steering adjustment. I feel like I need monkey arms to drive this thing
anyone want to buy a '07 Pathfinder ST-L? Will be selling the old one in about 3 months time.
anyone towed with a 4cyl 2.6l manual holden rodeo ute?
i have one but not sure if i should fit a tow bar to it and tow or just get something better.
cheers
I have previously towed a car with one of those 4cyl rodeos. was using a hire trailer so it was pretty heavy, but car was only 1200kg but either way it sucked big time. 5th gear was practically useless unless going down hill. on a flat road you had to rev the nuts off it in 4th before going into 5th as if you changed early you'd loose pace in 5th. I would personally go with something else.
I've been using a Nissan Navara STX for the last couple of years, fantastic tow car. Had all the suspension upgraded to Pedders heavy duty suspension front and rear with airbags on the rear suspension. Went to town on the options and also fitted up some electric R35 GTR seats to it. Time has come to move it on..... Replacing it with something a little more German...
Link to details re Navara for sale
Looking at all reasonable offers. Not sure if I am allowed to link to the for sale section, if it offends anyone mods can take it down.
Seb.
  • 4 weeks later...
thread bump
anyway decided to sell the prado
she has done a good job over the last 2 years
(i am old now and f*ken posh and shit)
so anyway was looking at q7', x5's and towrags as a good tow vehicle(td).
x5 is out cause of ghayness
anyway after looking around i have stumbled apon cayenne and cayenne turboz for the same money(03-07 models with 100k and full service history)
someone talk me out of it, cause f**k me they go like stink.
ps i dont care about the fuel bill if i can get to 100km/h in 6 seconds with a trailer on
thread bump
Can't go past a towrag, got two (TD) in my garage and both are just brilliant for towing.
Not overly expensive for servicing etc either although I haven't had to replace much as yet...
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
