Just to get this straight.
How much am I looking at spending to get a regular BA Falcon into safe, reliable towing condition? I'll need:
A heavy duty tow bar (how common are these on Falcons, can I find them easily or am I better finding a good BA and attaching one?)
Transmission cooler.
Rear springs.
Decent pads. ~$500
I'm guessing the first two are required, whereas the last two are more for safety and peace of mind. Any idea how much these items would cost?
Cheers.
Im sure you could get a PWR transmission cooler kit for around $165, maybe a bit more? plus fitting obviously.
A set of helper springs is no more than $180
HD tow bar is ~$6-700 (depending on hitch or tongue)
Load Leveling kit is anywhere up to $1000 (all depends on ball weight and specific kit etc)
sway is mainly caused by insuffient ball weight versus total weight of the trailer. When towing with a normal car, they often have low ball weight limits. And if you load them up properly, the arse of the car is dragging on the ground. So you end up with people putting the car further back on the trailer to take weight off the tow car's rear axle. Inssuficient ball weight is the result and sway becomes a real risk on rough or uneven roads, crosswinds, passing trucks, sudden manouvers etc
anyone used a au falcon ute auto for towing a 33 gtst?
I use mine all day everyday to tow both car/trailer and all my work gear with no dramas. Pulls like a dream and better than my old VY that I used to use and being t-bar auto have room for 3 which is handy.
I've got upgraded suspension & brakes, aftermarket headers and exhaust, cam and CAI all thanks to Jim Mock which doesn't hurt either :D
  • 2 months later...
Not much chop for anything more than a box trailer.
I just picked up my new tow vehicle the other day - got a Ti Pathfinder (not the 550 though - that would cost me nearly $20k more than I paid for this one). Haven't towed with it yet, but at least the kids are kept happy with the rear DVD player now. I don't like that they've deleted the telescopic steering adjustment. I feel like I need monkey arms to drive this thing
anyone want to buy a '07 Pathfinder ST-L? Will be selling the old one in about 3 months time.
anyone towed with a 4cyl 2.6l manual holden rodeo ute?
i have one but not sure if i should fit a tow bar to it and tow or just get something better.
cheers
I have previously towed a car with one of those 4cyl rodeos. was using a hire trailer so it was pretty heavy, but car was only 1200kg but either way it sucked big time. 5th gear was practically useless unless going down hill. on a flat road you had to rev the nuts off it in 4th before going into 5th as if you changed early you'd loose pace in 5th. I would personally go with something else.
I've been using a Nissan Navara STX for the last couple of years, fantastic tow car. Had all the suspension upgraded to Pedders heavy duty suspension front and rear with airbags on the rear suspension. Went to town on the options and also fitted up some electric R35 GTR seats to it. Time has come to move it on..... Replacing it with something a little more German...
Link to details re Navara for sale
Looking at all reasonable offers. Not sure if I am allowed to link to the for sale section, if it offends anyone mods can take it down.
Seb.
  • 4 weeks later...
thread bump
anyway decided to sell the prado
she has done a good job over the last 2 years
(i am old now and f*ken posh and shit)
so anyway was looking at q7', x5's and towrags as a good tow vehicle(td).
x5 is out cause of ghayness
anyway after looking around i have stumbled apon cayenne and cayenne turboz for the same money(03-07 models with 100k and full service history)
someone talk me out of it, cause f**k me they go like stink.
ps i dont care about the fuel bill if i can get to 100km/h in 6 seconds with a trailer on
thread bump
Can't go past a towrag, got two (TD) in my garage and both are just brilliant for towing.
Not overly expensive for servicing etc either although I haven't had to replace much as yet...
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
