Well i've been told to make a build thread by damo (djrift)
I've been club racing my R32 GT-R for the past 3 years, and got it to the point where the car was too fast for club racing. It's a neat road car, so I didn't want to buture it with a cage and what not, and more to the point I don't have wads of cash to throw at it.
So after talking to some people before Targa I decided to get a gtst to race in the Tas Super Series. Then I cracked the shits after Targa (for more reasons than the crashes, but I won't go into that), and decided to build it in line with the Targa rules, with the plan to set the car up, and learn it in the Tas Super Series next year, and enter Targa in 2011.
I was lucky enough to find a car locally with no engine and gearbox, the chassis rails are straight as, and the only rust was under the rear pods. The guy was going to build it into a race car, but decided after pulling it into 1000 peices that he wanted to get rid of it. So a few weeks ago Dad, Damo and I went and picked the car up. We filled my car, Dads car, and the skyline with the parts. Damo said he was keen to help, so we'll be spending the next 6 months building it
Got the car to Dad's and put it in his back yard, while he cleared a hole in the garrage. While he did that i got a cheap GT-R bonnet, front bar, boot, and rear wing. And sold the gtst bonnt off.
awaiting a dirty cheap rb20
GT-R bonnet on.
Horay...finally in the garage on the hoist
still full of crap
wheel has seen better days
previous owner has removed a lard chunk of the tar :P
still left me with some to clean up.
ta da
removing the wiring loom
full loom out, and ready to be chopped up.
more sound deadener, this weighed 5.5kg....and hid more tar
fan, heater, ac, and pedels removed to get the deadener out.
horay...more tar
passengers side done :) just the center and drivers side to go.
i'm planning to get a bond weld-in kit now.
Edited by sav man
https://www.sau.com.au/forums/topic/278029-bens-r32-gtst-build/
Hoorar the ball is rolling as we all know you cant actually build a race car without a build thread. they just never get finished other wise.
i think you forgot to thank damo for being such a grate bloke. then for finding a Grate Gtst for you and also letting you work on his Gtst to show you how much more fun they are to work on than GTRs.
many fun times will be soon had on this car and hopefully ben will keep the pics flowing.
Benny, let me know if you want my fully hectic Apexi N1 coil overs for the circuit.
Otherwise, I too am interested to know what you're thinking susp wise? Interested in joining me in a bulk buy (well, two of us :down:) of some Murray Coote stuff?
The minimum wieght for Targa is about 1180kg from memory (factory -10%). So I'm planning to get as close to that as I can, so i'm cutting away everything i can, unfortinatuly my car is a 1992 model, and has the side intrusion, so i'm working how to cut that out. I'm likeing the look of some Buddy Club P1 QF wheels, as they are light as. GT-R lighter bits here and there, there are a few rusting GT-R's being wrecked in tassie ATM, and alloy dosn't rust :down:
Suspention will probably consist of GT-R sway bars. I'm planning to put pretty good shocks in the car, tossing up between, Bilsein PSS9's, Penske 8300's, and MCA's at this stage. I've run revalved Bilsteins in the GT-R for the pas 3 years. But the setup is a compremise between wet and dry, the shocks can handle a varity of spring rates. But you can really change springs between stages if it starts to rain. Drummonds don't seem to be that durable, I've spoken to a few people this year that have had seizing, and over heating problems with them. I'm not in a hurry to spen money there, going to do lots of research before I hand my money over.
Since I live 20mins from Symmons, and it only cost me $65 to get on thetrack whenever I want, i'll be able to spent time to learn how to tune the shocks.
Running gear will be stock, with a clutch upgrade, and maybe a GT-R diff center.
The cage will be pretty extensive as it's going to tarmac rally. High and crossed over side intrusion bars. I'd like to extend the cage to the front towers, been looking at Duncans cage to work that out. Not sure what i'm going to do in the rear with the cage yet.
If the Bens end up going Proflex, keep me in the loop. Good things come in threes :)
1180kg? Once i know how much my car owes me body wise i am keen to keep saving and get a carbon tailshaft and PPG gearset. Probably get better value out of that rather then upgrading suspension to Proflex from what i am currently running
If you have a few dollars for an RB20 PM me as i have come up with a pretty good RB20 combo that i am also keen to try when i get back to Aus :P It will be perfect for what you guys are doing.
will be very interested in this build as well :(
my 32 is slowly coming along atm... not going to rip as much weight out as you but looking at having around 260rwkw so that might help me along a bit!!!
do both front and rear r32 gtr swaybars fit?!? i was considering whitelines (i know cusco are lighter and stiffer but im a jew)
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
