Cable ties farken :)
Looks good and +1 needs rear pods!
Pair of rear pods would struggle to weigh half a kg haha
the point of the car is for minimum weight. if you had seen the effort we have gone to every where elce on the car than .5kg is good weight to us. i totaly understand that most people fob off weight reduction but its one of thoes things that if you are going to do it you need to get really anal about it. no point getting half assed. and to be honest it is very noticable the difference we have found from driving this to all the other skylines we have as a group.
also on anther side note. Bens vision was to run the full nismo/N1 aero kit which never had rear pods. what most people think are N1 pods are actualy trust or other pods. the rear pods do nothing for the cars performance or aero so they are un-nessasary. this car was built with only nessasary items installed. also if you look at most modern TA cars the rear area behind the wheels is usualy cut out to help the air excape from behind the wheel. some teams run multiple wings behind them to help smooth the air but we cant do this.
the conclusion is, no pods it is.
I never wanted the pods before we got on the weight saving campain. I just have never liked them, plus they only hold water and make the rear 1/4 panel rust out (which i've already fixed one time to many)
Why did you bother with the type m side skirts then? A little weight in those too.
How much do you weigh? Taking a decent turd will loose you the half a kilogram... I love how 100kg plus people talk about weight reduction (not saying you are one of them) when if they just layed off some cheeseburgers they would be a lot better off :)
There is no "nismo/n1 aero kit" for a gts-t, you can get type-m side skirts and rear pods but n1 stuff is for gtr's. also there are no "n1 pods" for a r32 gtr, they are only trust pods which look similar to a gts-t's type-m rear pods
You could always just drill a drain hole in the bottom of them to disperse the water... I've never seen that issue on a 32 before. The only rust we see is rear 1/4 panels on the 4wd gts4's or gtr's
the idea was to make the N1 side skirts fit. im pretty sure we all know the difference between GTRs and Gts-ts. im pretty sure i already said there was no N1 pods but you must have read over that.
we have found one company that makes N1 style skirts to fit gtst but haven bothered as yet.
like i said before if your not into weight loss on a car than you will never get it. its a combination of many small parts that weigh half of f all that makes the difference. serious people will un-tack or cut off every un nessasary bracket and cut the extra length out of every bolt just to save 5kg over the whole car. most people think once they have removed the ac and back seat they have removed every thing they can. the point is weight is free power and free brakes. simple physics.
wrong.
see we rubbed all the paint off where the stickers were going then rubbed some of the metal back to save a few more grams.
this also ensured a seemless join between the sticker and original paint
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
