Well I killed another engine, but still finished 5th (was 2nd at the time)
here are some stages
Paloona 2nd fastest EM car
Plimsoll fastest EM car
Edited by sav man
I'll have to pull it down, but i'm guessing the valvle didn't close properly for what ever reason, and it gas axed the side out of it. We checked plugs, injectors, and ignitor on the side of the road.
We rounded that GT2 up 2 stages in a row!! There will be more stages uploaded soon.
I wondered what happened! I saw you were 3rd going into the last day and then finished 5th. Time for a 2jz?
It was 2nd, and no shitty Toyota engine is going in my car. I've done a different thing each time from the bottom up, so now i'm at the top, the next engine will be fine.
Rinadeena looks like an amazing stage...absolutely hammering! Suspension looks planted. OK, time to start flogging your spec Penskes to the rest of us :)
I did almost poo my pants at 10:25 when the car jumped sideways. If you want some I can put you onto my tuner, he organised all the valving. still learning a lot about setting them up, but being able to adjust hi and low speeds separatly makes a big diference in changing conditions. Any good shock can have my valving applied Penske/ohlins (sweedsh)/mca/proflex.... But it's probably cheaper to get the Penske's out of the states, and revalve them here
the bloke that done the specks on the shocks is about to do the same thing to a old set of jap ohlins that i got ahold of. they only have one twiddle valve but he said he will get them close enough.
this year ben adjusted the shocks at least every other stage and the car got faster by the end of each day and once it rained he new what way to go with them. it would take a few club days to dial these in perfect so its not a set and forget part. just for anyone elce thinking they mite like to spend the money. beauty of a bilstein is you cant adjust it. haha.
Starting to sound like a 300zx, 5 days... Engine out Lol! I won't touch it next year, promise!
PS where is the adjustment on the Penske's??? The KW we ran were easy to adjust on the front, but UBER gay on the rear.. especially on the side of the road between stages
c'mon a 300zx need a engine out every stage.
The penske's are upside down (shaft at the bottom), and the remote canisters are under the boot and bonnet (high and low speed bump), so the bump is super easy. Rebound is on the bottom of the shock, and required laying on the ground. But I didn't change the rebound very often.
haha well you were damn luck it was running at all.
I'd be pulling, checking and cleaning the head. When I snapped a cam it f**ked the tunnel as well and it needed to be machined straight again. Also, you will have aluminium everywhere including the sump.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
