Here's today's efforts, we have stood around for the last 3hrs having a few beers appreciating our last 2 and 1/2 years + of effort and myself, my brother and the old boy are extremely proud of this car and $200 000 + later, it is worth every cent and probably wouldn't change a thing on it and I must say for a backyarder shed job it would have to be the best R32 GTR i have ever witnessed personally and can't wait to go toe to toe with the worlds best. I still can't believe how awesome this machine looks it makes the R33 look like shit hahaha!!!!! A few more things like the carbon aerolatches and the doors skins and windscreen wipers are about all thats left and a good day of cleaning it and its ready for the photoshoot, hopefully gracing the cover of HPI Magazine very soon. The first person who scratches this car my old man with probably kill them but at the end of the day this car was made to break records and hopefully the R32 will deliver ...as long as the driver has it all under control, 8.7sec here we come. P.S for those that are curious the back of the car is 10mm higher than the front, it was just the un-even ground the car was parked on that why it looked weird thumbsup.gif.
Here's some more pics:
Notice how the old man gets his ugly mug in ever photo!!!!!!!!!!!!!
AME Tracer TM-02 19x9.5 +22 with Advan AD08 275/30 R19
i was always of the opinion that 19's were too big for an r32, that is, until i picked up my replacement r32 & after looking at your pics as well as the gun metal r32gtr garage saurus with carbon panels...it really confirms for me that 19's are the way to go!
looks awesome mate. I love it. makes me think my next GTR will be white too. I had a nice white 32 a few years back and always had a bit of a soft spot for them. hope it runs fast like you want it too. :)
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
