Hey guys, jst thought id share a little info i got from a little test i did regarding those 'octane boosters'
anyways I recently filled up with a bad batch of fuel and im getting 'safe' but increased knocks then usual; normal from watching my pfc hand controller for the past year is 13-27 (max 29-30 on a hot day)
With this current batch of fuel im getting 37 average at 6000rpm 2nd gear and 5000rpm 3rd gear.
Info from pauls pfc faq tells me that its still safe but i thought it would be a good chance to test some octane boosters to see if there is a difference. Anyways I drove the car as-is; warmed it up for 15 minutes and ran on a stretch of road in 2nd n 3rd gear (2nd to 6000 and 3rd to 5000)
Result was: 38knock in 2nd, reset n 36knock in 3rd.
I added the nulon octane booster (the pro strength thing from autobarn at 25bux) and drove for 10 minutes to disperse the contents then ran the same stretch of road again; results were: 25knock in 2nd @ 6000rpm and 29knock in 3rd @ 5000rpm.
anyways just wanted to share the info with you guys cos im pretty happy, dont take it as 'proven' jst wanted to share.
-Johnny
https://www.sau.com.au/forums/topic/285847-octane-boosters-test-n-results/
Didn't some mag do a test on all the octane boosters and the Nulon Pro Strength was the only one that made a decent difference? While working at Autobarn the Pro Strength was definetely the best seller.
Edited by PM-R33
I find they work well with shitty fuels, but don't expect it to anything after adding it to fresh premium petrol.
I have an octane booster that I import from America for about $2.50 a bottle (treats 20 gallons / 80 litres). When I mix that with regular unleaded it feels just like Optimax.
One thing to be weary of is these additives sometimes leave deposits in the fuel system.
Ive tried heaps of them and i found out that the only one i noticed made a difference in driving as well as knock was the Nitro NOS octane booster ill post a pic up so you see which one i mean but these do come at a cost though at $40 a bottle to treat one tank of fuel lol and i also found that martini ones are not bad either but be careful, some of them contain lead as well as other chemicals that are not good for Oxygen sensors valve seats and etc.
heres a photo
agree with the others, i dont see the point of octane boosters
either
a) get proper 98 fuel
b) tune your car on the best fuel you can get ie 95 penis if your in a shit area etc
c) if you get a bad batch of 98 PFC users can use temp ign adjust to back out a few deg, or just baby it around
c is my preferred if i buy 98 and its penis fuel 98ron
b is recommended instead of using 95ron and octane booster each time
a is preferred for all around
i found the big wynns race formula to be the best... mind you i just bung the lot in.... they are all evil on spark plugs
http://www.wynns.net/retail_raceformula.aspx
http://www.wynns.net/product_files/Race%20...43905%20PIS.pdf
Edited by URAS
This Bob Komtel - Street Machine article mentions it, and IIRC he wrote another column about a comparison of octane boosters and Nulon came out on top. Cant find that one tho.
you cant say its a waste of money, its just over priced for what they are.... and they dont create deposits, if anything they help burn the build up and clear it away....
it definately reduces knocking which on a track day could save your engine, not everyone tunes their car every time they throw on new bits... fuel is never at a constant ron rating.... sometimes we will think we're buying 98 ron but we get 97, sometimes its 99, if a car is tuned at 99 and you get a 97 ron in it you will feel if not hear the difference.... then octane booster will help aswell.
ive only used the stuff once and the car does run smoother, but thts in my car, yours may behave different.
either way the stuff is too expensive for what it is
And here in lies the problem :laugh:
If you love changing plugs every few tanks - go for it.
Otherwise, just use good fuel.
Octane boosters are a one-tank wonder, nothing more.
The best thing you can do is buy a drum of race fuel, mix a tank 30/70, much better than these additives.
Thankyou for this reply, i actually went to autobarn to buy a drum of race fuel to mix a tank but they said that i required some form of liscence to buy it; now is this right or is the bloke at the store just a 'know-nothing, know-it-all'
seems they had a leaded 100octane there for 75dollars/20litres
I actually bought 2 addidtives; the nulon one and another best seller which ill try next time.
with this new spark plug issue thats jst come up, ill be looking at mixing race gas with my pump tune for a litttle extra safety.
any info on the liscence???
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
