hey guys!
Got me "32 RB20 hotted up at bit.
As you know they kick arse on v8's (just like all RB's!)
Was playing around with me mate and his vs ss thats strocked to 355 and he beats me off the line but when i come onto boost he has trouble staying with me :happy:
Anywayz... finally get to 180kph goes about an inch of the dial then speed limiter kicks it!!! :@ Anybody know how to remove this cheaply without stuffing up any ecu componants?
https://www.sau.com.au/forums/topic/288440-r32-gtst-speed-limiter/
besides that you shouldnt be racing on the streets at that speed
I know you havent said wether its on the street or not but can tell by the way u say it that it is
Stop caring how much faster ur skyline can go then ur mates vs commy. Pull your head in, Doing those speeds on public roads is just stupid
I apologise if you are talking about this being on a track/strip but I dont think its wat u mean....
Actually for all you "street racing" haters i am not a street racer! The St.arnaud OFF STREET DRAG meet was on last week at the local airport and its an 8th mile track!!!!! So NO i am not doing over 180 on the streets!!!! and NO nobody is in the vehicle with me!!! It is just quiet embarrasing when the speed limiter kicks in whilst draggging LEGALLY!!!!
johnnilicte! why bother writng on this thread if all your guna do is play secrects!! Im sure i could google how to cut the pin u cut but if im guna remove it im guna get it done properly! FOR TRACK PURPOSE ONLY!!!!!
once again im dragging LEGALLY ON A DRAG STRIP!!!!!
Nistune can defeat the limiter (infact set it to whatever you want, 0 - 514km/h). Can cut that ECU wire but I believe it messes with HICAS or specifically the speed sensitive steering (since it basically reports the car is going 0km/h all the time)
wow, you can hit 112mph after 200m? in a rb20 powered car with stock ecu and just a rb25 turbo? that must be the most powerful rb20 in the cosmos, because i've been in a r32 with a pfc and bigger turbo and it was only just able to crack 100mph over 400m, so the fact that you can be doing 20kmh faster after 200m less is fantastic. what sort of flux capacitor do you have? and where do you have your mr fusion mounted?
oh and the reason why your mate can't keep up once you come on boost is because the 200m is already over and he has beaten you so he has backed off. or he only has 4 spark plugs connected. rb20's are by no means fast even with a bigger turbo. they might beat a v6 commodore, but a 355 running properly shouldn't have too much beating a rb20 with a rb25 turbo on the stock ecu on 10psi
You are doing 180km/h on a 8th mile.
I've never heard such RUBBISH.
Next time you post about street racing - i'll ban you. Make sure you understand this very clearly.
Guest
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
