Just to chime in that there is another factory super turbo.
Golf GT :Dhttp://www.webwombat.com.au/motoring/news_...f-gt-review.htm
Love these cars and enjoyed the episode from mighty mods :).
  • Replies 80
  • 6 months later...
an update.....
we (well maybe I) decided it could live with some more turbo lag with the SC to look after things down low.
So it is at Hills Motorsport getting a GTR T28 turbo and new manifold put on.
At the same time it became clear that it has a fair bit of blow by already, so we have order a set of forged bottom end bits from some wierd little japanese car guy in hokaido that used to race them. and a catch can to keep it sort of under control in the meantime.
yep it says "an intake restrictor". that got a bit tricky for GTR with 2 intakes but the mighty march only has 1 intake.
I figure the only chance for a turbo car in IPRA is either spend way more than 1 can afford, or something light and small enough that the restrictor won't limit power. No chance of 900cc making make 350hp so I am safe.
oh yeah, just reminded me, the GTRs or and other car with 2 intakes need to run 2 26mm restrictors.
lol 7 bar sounds nice. might have a bit of trouble holding the head on.
in unrelated news....I saw pics of the super turbo's older brother today....its a 1985 K10 March Turbo. Love the dash and steering wheel...
they dont have any trouble holding the heads down, the problem is stopping the block splitting in half and leaving the crank + pistons down the bottom and the head/cyls elsewhere. :/
Just reading the regs on all of this duncan, I think you'll be stuck with two restrictors...
For vehicles utilising a turbine type compressor, the restrictor must be fitted as per diagram 254.4 (see “Rally/Road” in the CAMS Manual of Motor Sport), save that the maximum internal diameter of the air intake into the compressor is 36.0mm where a single supercharging device is fitted, or 27.0mm where two devices are fitted.
PS: I haven't finished reading ths damn 3 million page long manual, so there may be something I've missed...
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
