Spotted GD2ILA 33 GTR on comenarra this morning waiting at ryde rd lights round 8am. Always spot you. I was in the black 32. I'm usually in the sprinter though.
Also spotted a nice black 34 GTR round 630pm at lane cove rd/epping rd intersection.
Yup 'dats me on my way to work every morn. Nice to see yr 32 - were you the one doing some kind of rd work @ yanko? Saw it parked there all the time.
Na that wasnt me. I saw that 1 parked there everyday aswell with a rexy and some utes. Think they were landscaping or something. Mines black m spec gtst with gtr front bar and stock wheels.
Spotted.....a dark grey R35 on epping RD heading towards the city at about 7AM.......considering I have drive about 3 of them now on the track this is the first one I have seen on the road since there release....go figure :)
Ah ha! I think I spotted you this mornig about 7:20 right before Kissing Point Rd - well Black R32 at least if it wasn't ya.
Spotted a white R34 with what looked kinda like a Nismo stripe kit (red, grey and black) on it, no rear wing.
This was in the main street of Toongabbie around 2.30pm.
on saturday spotted a black 33 gtr at castle hill, gave a wave n got nuffin back u effin snob!
also a white 32 with a wing n black wheels sumwhere round castle hill not quiet sure where i was lol
Spotted this same car again this evening around 6.30pm on the M4 heading East, just past Homebush. Number plates were PL34ZN.
Spotted White R34 on The Mooney Mooney Bridge Saturday morning heading south gave me a wave.
I'm pretty sure that was me. :) Were you heading north? I was on the way to a JDMST meet.
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
