Lol had to laugh when i got back to my car to find 2 P plated R33's sitting beside my GTR at Rouse Hill shopping centre today
one was series 1 and other series 2.
They'd obviously rather park next to a dude who won't put door marks on their cars :) + of course, pride in the Skyline :blush:
think thats bad? went to supercheap to pickup some oil on the weekend..
+ their was another black s1 behind that van and the franchise owner's stock 33 gtr on the street..
felt so damn "un-unique" yesterday lol
Me and sean spotted today
a Black 32 GTR with white rims in wisemen's ferry and a R33 4door parked behind my GTR
a gun metal grey R35GTR with plates :LOCKON" in macquarie st, Windsor
and a White R33 GTR with top secret body kit going past my house lol
all great looking cars.!! :(
all great looking cars.!! ;)
Thought the R32 at Wisemans was Dark metallic blue?
The R35 does move smartly off the line :)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
