Lol had to laugh when i got back to my car to find 2 P plated R33's sitting beside my GTR at Rouse Hill shopping centre today
one was series 1 and other series 2.
They'd obviously rather park next to a dude who won't put door marks on their cars :) + of course, pride in the Skyline :blush:
think thats bad? went to supercheap to pickup some oil on the weekend..
+ their was another black s1 behind that van and the franchise owner's stock 33 gtr on the street..
felt so damn "un-unique" yesterday lol
Me and sean spotted today
a Black 32 GTR with white rims in wisemen's ferry and a R33 4door parked behind my GTR
a gun metal grey R35GTR with plates :LOCKON" in macquarie st, Windsor
and a White R33 GTR with top secret body kit going past my house lol
all great looking cars.!! :(
all great looking cars.!! ;)
Thought the R32 at Wisemans was Dark metallic blue?
The R35 does move smartly off the line :)
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
