Spotted Humbla on the Hume Hwy yesterday and cruised together for about 20k's. :action-smiley-069:
Our lil cruise was nice till a fool cut in front of me and slowed down.Was lovely to see your smiling face again. :action-smiley-069:
Saw 2 White R34's separately 30 mins ago at Bella Vista. 5:30 PM
One going going north on Old Windsor Rd passing the traffic light near BP gas station and Maccaz
I was exiting the gas station so couldn't get a good look.
and the other one parked outside 20 Lexington Drive. Had no spoiler. Love the body! thumbsup.gif
This thread needs more ictures of spotted cars. I have been on here searching for any spots of my old car... I miss her. And RTA search reveals number plate has been changed :( Will I ever see my baby again :unsure:
Yer on green parker and one head light lol i thought was 32 rear 34 front but didnt get a good enough look at the rear.. You wouldnt have seen me i was in a green 2011 fiesta :-P
car looks phat mate..!!
Hahah yeah.. the dreaded one-eye r32 headlight ailment..I need to pull the lightswitch apart by the sound of things :rant:
...and the green parkers certainly add some wank-factor :rofl2:
It's a work in progress, though it'll never be a show car I like the 'beef' that the wide 34 panels give :turned:
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
