All spotted in Albion Park today.
White R33 GTST S2.
Lilac R32 4 door, no. Plate SXC 32.
Silver R33, huge GT wing and custom plates at, Frankie's Auto electronics.
i see that 32 parked on the highway every weekend...
and my blue 33 in the garage sitting and waiting for the pass pie cruise ;P
Saw a Bayside Blue R34 GTR cruising with a blue WRX on the Hume Hwy after merging onto it from Picton Rd. Looked so mint, I was jelly. Lol
I was in the Silver R34 25GT about 150-200m behind you.
Also, when's this cruise to Robertson Pie Shop? I live in the surrounding suburbs so I could probably meet you guys there.
Edited by JDM34
March 11. Guys will be coming from Casula down to meet up with others at Albion Park (on Tongarra Rd across from the Caltex; in front of St Pauls I think it is) and then up. I'll try and get down there early to get the liner and scout it out. Check the thread in the Events section.
Cheers mate. Yeah, I have that day off so I should be able to make it. Won't know anyone though. :nyaanyaa:
Left a reply in the thread as well.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
