REAP3R @ Darling Quarter Parking. Lost for words.
1064768_10201471313169172_1247709468_o.j
Thanks :) It's slowly getting there
^^^ That is pure porn. Didn't it have white rims before?
Yeah had white te37's. I've still got them right now but the tyres are shot
Spotted a white R32 GTR and a silver R33 GTS-t heading south through Warrawong today around lunch time.
The R33 had an SAU sticker on the back windscreen.
Looks like you created your account to advertise the car, coincidence aye
mxzoom
Member Since 13 Jul 2013
Offline Last Active Jul 13 2013 08:04 AM
then you posted the same ad here:
http://www.skylinesaustralia.com/forums/topic/417696-the-edward-lee-hakosuka/page-2#entry6925414
good forum manners.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
