naughtyruski - saw you drive past my house a couple of times on the weekend
haha, really what suburb are you in? I have been driving around a bit. Still trying to get the thing registered and get the engineering certificate sorted out, couple little dramas and some Dickson RTA jokes to tell, dickheads. So I have been cruising around a bit while i have got the permit. Cant wait til its all over and done with and I can actually drive interstate!
https://www.sau.com.au/forums/topic/30059-spotted/page/487/#findComment-3950436
ooh ooh me me :P I managed to snap the pedal box in half on mine :) . Rewelded together later :)
turns out i snapped the pedal assembly and snapped the pedal assembly off its mounting point on the car. gotta get it towed home and start pulling the dash and everything out to weld it :banana: gonna be a fun job :banana:
thanks naughtyruski. your ride is very tidy, good luck with rego, least they wont get you on exhaust noise :)
https://www.sau.com.au/forums/topic/30059-spotted/page/487/#findComment-3951855
i'm in nicholls
saw you on horse park drive the other morning as well.
i was in my commy tho
https://www.sau.com.au/forums/topic/30059-spotted/page/487/#findComment-3952408
i'm in nicholls
ahuh I think I saw you standing outside when I drove past. So that was your R32 out the front.
Yeh just went to a mate place to check out the new GTA on PS3.
https://www.sau.com.au/forums/topic/30059-spotted/page/487/#findComment-3954058
turns out i snapped the pedal assembly and snapped the pedal assembly off its mounting point on the car. gotta get it towed home and start pulling the dash and everything out to weld it :P gonna be a fun job :P
thanks naughtyruski. your ride is very tidy, good luck with rego, least they wont get you on exhaust noise :blush:
Thats some shit circumstances mate, sad to hear it. Hope it all works out smoothly though. Yeh didnt pass at dickson, had about 7 of the dickheads looking at it at the same time, all the old pricks came out to look at the car and pretend they have a clue what they are looking at. got a few things i need to fix, not major, except they didnt like the engineers report at all. Cost me a fortune, hope its not a drama to sort out.
Saw a Silver R32 GTR parked just down the road from city west carpark. sweeet!
https://www.sau.com.au/forums/topic/30059-spotted/page/487/#findComment-3954068
Spotted 3 SAU members cars at Trojan today, turning into the SAU parking lot lol.
Also spotted michelle in Tuggeranong in the 4dr around 4:35pm, chucking a u-turn, tsk tsk :cheers:
ur allowed to U turn there :D there is a little u turn dotted line there.
https://www.sau.com.au/forums/topic/30059-spotted/page/487/#findComment-3956442
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
