Spotted a mirror image Silver M35 Stagea on Parkes way yesterday morning 830ish. Felt weird.
I spotted a silver M35 in fyshwick this arvo at about 5:40 on woolongong st as I was leaving work. Was also wierd... I was thinking to myself "what the hell is someone doing driving my car?? especially since the turbo is blown atm!"
First M35 I've seen getting around since I've had mine.
https://www.sau.com.au/forums/topic/30059-spotted/page/598/#findComment-4981186
all black r33 with black wheels (looked frickn tufff!!!... for a 33 :worship:) coming out of bruce around 1245 yesterday afternoon.
also a silver r33 with a pearl in it and chrome multispoke rims near immigration in belconnen at around 1235 yesterday afternoon
https://www.sau.com.au/forums/topic/30059-spotted/page/598/#findComment-4981922
Spotted a 4 door R32 with P-plates and a Federal sticker on the back window (same as the one now plastered on mine lol) at the Shell on the Hume yesterday arvo. Had quite a loud exhaust.
Possibly Rebecca (Michelle G daughter, I am pretty sure it has a federal sticker on it)
p.s. This is melly
https://www.sau.com.au/forums/topic/30059-spotted/page/598/#findComment-4991955
p.s. This is melly
I thought of her actually, but I thought the car looked different... but I could be wrong :3some:
Was she at the OP thing that Reece & Zane were at?
https://www.sau.com.au/forums/topic/30059-spotted/page/598/#findComment-4992144
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
