Yellow 34 southbound on the Monaro hwy yesterday around 1130, just north of Bredbo.
Flashed lights and waved but (reflection on windscreen) hard to see if any response.
And then...just the other side of Bredbo at 1620 the same car heading back north as I was heading home from CBR.
Definitely no response to waves, etc. this time.
Very nice car...looks like the one in Shell,s ID.
https://www.sau.com.au/forums/topic/30059-spotted/page/937/#findComment-7279119
I've recently sold it so it might well have been my old car. The new owner has a beard if you happened to see him!
https://www.sau.com.au/forums/topic/30059-spotted/page/937/#findComment-7279727
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
