Spotted White R32 GTR driving past the shell servo in belconnen, this was a few nights ago, plus it was wet, oh boy did my beast kick out good too. so hard to keep it stright. gotta love that RB25.
Saw you parked in Manuka...friday night maybe? Mighta been SUnday night. I forget.
https://www.sau.com.au/forums/topic/30059-spotted/page/33/#findComment-890060
spotted: Black R33 GTR on haydon drv tonight. very sweet ride
Thanks Sigputnik, although she's not as nice when you look close up. keyed down drivers side, 2 dents in passenger door from nice people opening onto it, interior wrecked from another nice person borrowing my stereo without asking me and the front bumper is crooked care of my housemate.
but thank anyways, appreciate it :)
https://www.sau.com.au/forums/topic/30059-spotted/page/33/#findComment-890267
RB25 in a GTR?Sure about that?
https://www.sau.com.au/forums/topic/30059-spotted/page/33/#findComment-890806
Lemon/lime gtst northbourne ave, last friday, interesting colour, tidy unit.
Metallic pink gtst approx, 94/5, Shell servo at Yass last Friday.
Silver gtst just outside Tumut Sunday arvo ,with ACT plates, I was driving the tipper, you wouldn't have noticed me.
Anyone here????
https://www.sau.com.au/forums/topic/30059-spotted/page/33/#findComment-895214
Aurora and Amaru's toys, outside subway in the city @ 12:30... least it sure looked like em. I had a look around and couldn't see you guys.
well my car was at home in pieces for most of yesterday and last night so it wasnt me out... doh!
https://www.sau.com.au/forums/topic/30059-spotted/page/33/#findComment-895268
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
