…..and this is for an up and coming Pro Compact 4 cylinder front runner. It was picked up today . The FE3 which should be packing some serious punch.
This is my favourite photo
Next weekend is the RB30 Street Version group buy.
Happy Welding,
Ariel
Hi Ariel,
Great work! Who did you build this for? I bang around in the hipo fwd Mazda world and there is not many people building FE3's, so I probavbly know them! Out of curiosity for my own project, can you PM me with prices for something along these line please? :-)
  • Replies 246
Posted Images
  • 3 weeks later...
nice. just one question on the previous page pics. how do you get the injectors in if the rail is welded to the runners like that? i guess just have to lever it out of the way?
the rail mount is just bolted to the bottom of the rail so it makes it easy to take on and off
I am testing a new torch setup over the weekend on a ca18 manifold so lets hope it comes out even better
Edited by ISL33P
Nice looking work there.
Just a quick enquiry, a little down the track i'll be looking at getting a custom plenum for my rb30, however, due to my setup i want a plenum that is the same orrientation as a standard nissan plenum (ie; the intake and throttle body runs over the top of the engine). Just wondering if you would be able to do something like this? And roughly the costs? I'll be wanting a bigger sized throttle body. And also would like to replace my entire plenum (both the top part and the bottom part) as i'm wanting something that isn't going to hold my setup back.
Here's an engine bay picture:
And a link with some more info on my car (needs updating):
http://motamota.r31s...?topic=146624.0
The black intake pipe you see in the picture can be lengthened or shortened where needed but i figured it would be easiest if the throttle body remained in the same position so that the throttle cable connected as normal.
Like i said, i won't be doing this for some time (unless it turns out to be affordable sooner or i decide i want it done sooner) just wanting to know if you can do it, how much roughly, and any recomemmendations you have.
And should also mention that a forward faceing plenum would be no good to me.
Cheers for your time.
Kurt
Nothing special at all actually, just a wp20 watercooled torch, with now a cheap gas lens setup off ebay. I might extend the tungsten out to 5-6mm but apart from that I just crank the heat up for tight spots.
Cheers,
Ariel
  • 3 weeks later...
  • 1 month later...
Sick of custom plenums......well there is more coming LOL but for the time being, here are a couple of a surge tank and breather I made recently.
Coming so are catch cans, surge tanks, breather tanks, overflow bottles, wiper bottles, ABS covers, airboxes and more, so keep an eye on this thread on how they all come together
Edited by ISL33P
  • 1 month later...
Hey mate epic welds and fab work u got going on I literally am in awe :-0
I am sheety and was just wondering if u do all of your ally welding with pulse ?
Do u use 4T button setup at all or foot petal aswell ?
Just curios mate your runs are awsome :-) can't wait to see more
    • Saw this video today from Adam LZ.    Long story short is he is claiming that the load from the engine fan once the fan clutch heats up(engaged) is increasing the getrag rattle(at idle) when you don't have a dual mass flywheel.  Before I go buying an electric fan setup .... Anyone heard of this ?    I must admit when my car is cold the getrag is pretty quiet and I do notice the rattle after it is all warmed up. I've always assumed this is due to the gearbox oil temp and tolerances of metal.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
