I have had it the last couple of year and im rebuilding it it has prety much every thing is new im not gana go in to detail but it has 18inch chrome rims/full 400r body kit /aero mirrors/pod.3inch exchat/clear tal light/white interor/ and a alot moe but yea
makes 250rwkw 12psi
ill put more pics up like tomorow
https://www.sau.com.au/forums/topic/305747-rate-my-skyline/
  • Replies 211
Posted Images
Replace wheels with something NOT chrome, replace the wing (or add a drift lip), and lower it at least an inch or two, and then you'll be heading in the right direction.
4/10, but these are just my views...
https://www.sau.com.au/forums/topic/305747-rate-my-skyline/#findComment-5057340
remove sticker on rear window
put the spoiler back on
change the rims
never get chrome anything. less is more
5/10 - average as a mother
that's my taste anyway
+1 totally agree i couldn't give it anymore than 4/10 just looks silly without a wing and those wheels.
https://www.sau.com.au/forums/topic/305747-rate-my-skyline/#findComment-5057434
because of the lack of wing and poor choice in wheels, you cant tell you have put alot of effort into it.... or that it pushes out good numbers... it just looks like a typical half run down skyline...
dont mind the rear bumper though ...
5/10.... gl with it :) im sure you can get it looking really tough
https://www.sau.com.au/forums/topic/305747-rate-my-skyline/#findComment-5057526
makes 250rwkw 12psi
sorry, but you asked for my opinion, so i'm gonna give it, :)
rims - fail
no wing - fail
white interior - epic fail
clear tail lights - epic fail
2/10
get decent rims, put back the stock tail lights, drop it 2 inches, remove the sticker that says drift and you'll be getting somewhere...
remember this is just MY OPINION, and i'm not just being a cunt :D
https://www.sau.com.au/forums/topic/305747-rate-my-skyline/#findComment-5057557
250rwkw at 12psi!? what turbo.
Car - 3 stars
Picture taking abilities - 1 star
THe pic where taking in like 1min umm yea well i like my chromies i still run 11sec 1/4
I have drift r rims i might put them back on but i beat would be a lot quicker +the girls like the rims lol :)
https://www.sau.com.au/forums/topic/305747-rate-my-skyline/#findComment-5057602
rims - fail
no wing - fail
2/10
remember this is just MY OPINION, and i'm not just being a cunt :)
That's what I was gonna say.
Got any engine bay pics?
https://www.sau.com.au/forums/topic/305747-rate-my-skyline/#findComment-5057707
11 seconds with 250rwkw on those tyres and rims ay...what engine set up?
I have a book about how to tune i read it and just add some thing else and still runin stock turbo :) took all stuff out of my boot u can do an 11 sec pass with 200rwkw all really need is a good set up
https://www.sau.com.au/forums/topic/305747-rate-my-skyline/#findComment-5057832
so you're basically lying about power figures and ETs. You're dreaming if you think that the stock turbo can make anything NEAR 250rwkw with the stock AFM and computer as well.
I give the car 1 out of 10 only because the paint looks alright. Rims look like cheap shit with a crappy offset and don't suit the car, neither do Autobarn stickers or painting the interior white on a red car (clashes badly).
Put the spoiler back on, fk the rims and stickers off, do a LOT more research about RB25 modding and you've made a start.
IMO
https://www.sau.com.au/forums/topic/305747-rate-my-skyline/#findComment-5057854
IMO
it has after market prtey much evry thing the turbo is dieing but it lasted a good 3mouth and i got the dyno il get back to you when i findthe print out moved house some stuff in storage
https://www.sau.com.au/forums/topic/305747-rate-my-skyline/#findComment-5057865
i dont mind no spoiler.. i dont have one i hate those duck tail spoilers makes the boot look wayyy to high.
having said that wheels are woeful and i personally hate grandpa maroon..
by the way i think some of you are flaming a bit hard.. id like to see some of your cars ...
https://www.sau.com.au/forums/topic/305747-rate-my-skyline/#findComment-5057934
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
