Something twin charged, thats for sure. Looks like the turbo feeds into the supercharger, which looks like a factory unit, probs the one of the 4agze?? Or maybe they merge together, its hard to see.
Looks quite intricate though.
Im working on the merge collectors today and then onto the rest of the headers. I have holidays this week and I hope to get this part close to done this week!
Thats insane! Looks like it will rip some mean skids! Where is it located?
Here are the two merge collectors ready for vband rings, which I dont have yet...Anybody know of places that have 2.5" and 3" vband rings with clamps?
Got them expanded down the road at Macs Mufflers at Brendale! Did it while I waited which was good. Cost me $30.
Time to clean up the insides!
Justin, family business mate. Old man is the boss, knowing people helps with this kind of stuff.
Edited by r33_racer
All the merge collectors I found that could be bought from an exhaust shop were not proper merge style ones. They were the old fashion way with pipes tacked together and a conical sheet rolled around it and then shaped around the pipes and welded up. I wanted to this bit properly and challenge myself....it did take the better part of today though. But it was my first go at doing this....surely thats a good enough excuse lol.
Good thing GCG has the vbands! Woot! Problem solved.
Actually I have done abit. I havent bothered with a proper update yet as I never got the exhaust finished. I have done the extractors and down to the 2 into 1 merge and left it at that for the moment. As of today I have the motor and gbox out and the bottom end stripped for inspection and a few mods and tweaks to be done before it all goes back together and then back in.
I didnt go into any detail in making the headers like I originally wanted. They are far from equal length and abit messy. It took ages to do and it was a pita. I couldnt make it equal length or close too like the UK guys did in their race car because I still have heater lines and wiring and other crap along the firewall and so had to place things differently. But as you will see from the pictures 1,2 and 3 go where they need too inorder to clear the intake and 4,5 and 6 basically go straight down into the collector. The other main hold up before coating is my egt sensor setup from america is being held in customs as it was over 1k :( I gotta fill out all the bullshit paper work and go pay the extra tax before I can collect. Once I get them I can weld in the fittings and paint the whole thing or maybe get it ceramic coated and then heat wrap it all and have it ready for installation.
The motor looked great when stripped down. I rebuilt it like 3-4 years ago and since then havent looked after it very well, gave it shit oil and hardly changed it. The oil that came out of it was quite black and burnt. Yet the bearings were damn near perfect apart from a few polished areas on some, but the majority were still with factory coating and discolouration. I was amazed as this car hasnt been treated very nicely when it was being used. Many burn outs and thrashings have been given over that time!
So I gotta do a few adjustments to the factory oil pump and then some new seals front and back, fit the twin plate, possibly modifying the std sump to hold a couple litres more oil, reassemble the bottom end and then chuck it in and finish off the exhaust and fuel system side and hopefully try and get it started! :D With any luck I wont have a million things to try and fix before it runs reliably.
Thats about all I got for the moment. Once I get a good amount accomplished I will post up a big one!
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
