I had a look at the mufflers, the actual muffler shell is about 2-3mm bigger then the actual 4" in and out of it, so there is no real lip to catch so to speak. Suprising how compact these mufflers are.
The flex pipe in my setup is actually quite high up, from what I can see at the moment, the lowest part of my whole exhaust is at the base of the dump pipe where it comes out from the firewall. But, if I do make some kind of shield around the flex pipe, it may look like a cat! That could come in handy lol.
  • 3 months later...
Its on hold atm. Busy working on the race car and helping my old man work on his HR build. Add a gf into the mix and there just isnt enough hours to get much done lol.
I have supercharger pulleys machined up and ready to bolt on and pretty well everything done, just need the time to start fitting/hooking it all up!
  • 4 weeks later...
Damn that was an epic read. Got goosebumps from excitement. A really bloody nice job Mike. Nik here from email. Mate let me know if you ever want to give away the twin charge beast at all. Btw did customs charge a lot for those egt sensors a few years back? And you on another ECU? Finally, still E85?
Sorry mate questions galore, buy one get hundreds free.
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
