Looking forward to seeing this weapon on a track. What cam are you putting in the beast?
It's going to most likely end up with a custom ground cam... Not overly too much bigger then standard, it will move the power band up slightly, but basically going for EPIC lift in it.
lol cam. only 1. how quaint.
What is the plan for the starter motor Matt....stuffed if I can see how it will fit?
Going to use a standard starter. The rack is being moved to the drivers side a bit further.
And yes, only one cam... So much cheaper then buying two... :P
The idea is to have a moderate cam in it Mark. That way I don't have to rev it's tits off to have it make power.
Hey matt, great work so far!!!
Out of curiousity how much weight is saved over the RB setup?
I know that the LS1 engine is lighter an gearbox is heavier, giving better weight distribution, but how much weight is saved?
I haven't weighed my setup, but Stu who put an LS1 into an R32 found I think a 20KG saving over the RB20 and it's gearbox.
RB25 box is heavier, and I also had an RB30 block, with big heavy mani and turbos. So 40KG - 50KG saving at most I'd say. The big advantage is more the moving the weight from the front of the car to the middle of the car.
So, I gave myself a birthday present of a day off work, and decided to head up to take some snaps so Brad didn't need to worry with photos.
From under neath
NICE AND EASY OIL CHANGES
Holden thought of the R33 when they made this sump... It fits perfectly...
SINCE WHEN DID HOLDEN START THINKING?
Supposedly a cat lives here...
AND A SPIDER
I'm going to need to change this
NAH..JUST CHUCK SOME MORE GREASE IN IT
This will cause issues...
NOT IF THE STARTER MOTORS ON THE OTHER SIDE
See... They do fit...
SO WILL A 500MM RADIATOR WHICH IS GOOD FOR HOT DAYS
Just...
YOUR GUNNA PUT ZOOMIES THROUGH THE BONNET YEAH
Although, it does sit nice and low...
AND A SUPERCHARGER ON TOP
At least I can get to the gearbox bolts easily...
AND YOUR STARTER MOTOR....OH WAIT!!
Because of how well the sump fitted the cross member, it's staying where it is, as you can see, it could be shoved back a bit, but that sump is such a good fit!
Good to see shes coming along nicely.. :thumbsup:
  • 4 weeks later...
So this is a bit of a sore point for me, but I'm looking at putting this up for sale after Brad finishes his bit of the work.
That would be all wired, mounted, tail shaft in and rack modified. So still a fair bit to do to get it running.
If anyone is interested in it, give me a yell and we can talk more.
It is only EOI that I'm looking at. If you make the right offer... It's yours.
I've got some new plans coming up, so, kind of looking at passing this on, OR, it goes to the back of the yard at my parents place for a year or so.
I had an ls1 in my r32 gtr. they fit great and are so much lighter than the RB engines and so much cheaper to modify. i modified the sump and got the engine sitting a little further back and had no issues with the rack. Great build keep it up.
Is the cost a bit scarey for you?!, or do you just want a car on the road?
Karchers v8 180 thing is up on stands for a few months now!...again >_<
P.S
finish it!
Nothing to do with the cost, I actually want to keep it and get it on the road.
Plans are completely non car related actually.
It's either keep it, and it goes in storage for a year or two, or pass it on and let someone finish it with the hard yards done.
Hey, if i can offer some advice on LS1 cams...
Oztrack tuning (Steve) do some magic cams, only slightly larger than std, but still retain driveability..and make great power. ie 220/220
he also offers remote (tuning if you need)
  • 4 months later...
So... Brad's going to kill me... But I was sitting in the car the other day... And well.... All this shit randomly fell out...
Along with all of that, this was on the drivers side, just under the back window... I believe it is the high speed fuel pump relay? Can someone confirm?
Also, this box sits bolted to the inside of the rear guard beside the aerial unit... Is it apart of the aerial stuff or for some other lighting?
Also, HICAS ECU is GONE!
HICAS Wiring to under the car is GONE!
Now to install HICAS Lock Bar... Hmm...
Then I also need to finish removing the rest of the body wiring loom...
Things such as rear wiper and wireing... Gone. Aerial, Gone, Speakers, Gone, random aerial cables, gone, sun roof cables, gone. (Need to remove the sunroof once in a garage and fit an aluminium sheet + brace in the roof.) Everything under the dash is GONE except for wiring... And it will be ripped up soon for my custom wiring loom...
My step dad has "volunteered" to help me wire that up and make some custom fuse/relay boxes which will be mounted on the rear floor I think... Or in the dash board on the passenger side...
Made a decision to rewire alot of the car, I want cables in different locations, so I can move switches etc, as well as pull as much dead weight as possible...
I need to chase Neil's cars weight... I am going to be disadvantaged though, as I am a heavier driver... But I will be rewarded in weight by not yet having a cage... Yet...
Also need to get some aluminium and make some door cards, as well as the "dash board".
Got lots of sound deadening to remove... Need to do some shit to this car myself (Happening slowly, but hard when I don't have a garage) and then I'll be sending it back to Brad...
The exhaust stuff is sitting in my lounge room... Along side bags and boxes of other odds and ends to make this thing go...
I just need to go purchase a dremel and the exhaust stuff will go in... And random brackets will come out...
What my work doesn't currently realise, is how much shit is about to be put in their massive bin next time it is emptied...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
