Mechanic found all rust in the chassis. all that money down the drain, if he doesn't refund then off to court we go.
dude that sucks so f**king bad..
hope i dont get a lemon when i buy my car
Gah, that sucks but it's not the end of the world. It is possible to repair rust in chassis rails. You will need to have it engineered, but it shouldn't be too much of a headf**k.
That is, of course, if you have no recourse against the person you bought it from. Was it private or thru a dealer? If private then you don't have a leg to stand on (unless he supplied the RWC - you will then have to go after who ever supplied the RWC), if thru a registered dealer then you should be able to get your cash back (even if outside the 30 day warranty period as it is a chronic problem that must have been affecting the car prior to you purchasing it).
GL with it!
GL with it!
Yeah I posted one page back but that was through our mechanic, took it to a proper body shop that's been in the business for over 30 years and he just looked at it and said its f**ked and you're a f**king idiot for buying it. It has rust in the front strut towers, all throughout the floor pan and in the boot as well, its too big of a job they have all agreed and a new chassis would be the only way to continue. It was bought privately from interstate (NSW) without a Roadworthy/Pink Slip, it has gotten pink slips in the past which is incredibly dodgy as without a doubt this hasn't just sprung up overnight. Currently it's not in our name we still have the transfer papers but we have paid the money to the previous owner. Waiting on a call from the previous owners father to find out if we're getting a refund or have to take them to court. I'm tipping the latter. If anyone want's to know the outcome of what happens here and if I keep looking for skylines after this situation just let me know and I'll keep you posted.
Cheers all,
Borci88.
Cheers all,
Borci88.
And if doubt get one of us to come check t out with you. Always good to go with someone who has one as they know what to look for. ( before you waste $400 for a vehicle check)
I've tried to get cars privately twice and nearly got burned both times, thankfully they only cost me a few hundred to get checked instead of the thousands the repairs would have cost. After the second I've vowed never again, it's LMCT or nothing.
Borci i rekn your best bet is to part the car out you'll pretty much recover your $7k.. going to court will take forever if you win..since from what i read you only have an old "dodgy" pink slip but i dont know how you can rely on that..? even though its a major problem over xxx period...
i mean if i sold my car with a 6 month old dodgy rwc..wouldnt mean much since its only valid for 30days regardless if its an ongoing issue your purchase wasnt based on that pink slip..
good luck anyway
Anyone go to the classic car show at flemington race course? Was huge.
Saw a merc gullwing, lotus esprit turbo, Porsche gt3rs and the first petrol car haha. He actually had it running and was driving around the car show. 2HP of fury
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
