lol that's what my P plate used to look like on my R32 in 2000. 3 years n a cop never said a thing about it.
and the wheels are SSR Vienna Dish... close :(
I see.
A friend of mine just bought an E50 El grand with Fabulous wheels and yeah, they look very similar to SSR Vienna Dish.
He is waiting on TEIN Coil overs from Import Monster and slammit! :)
oh and...
GTS logo I made from way back:
and evolution of the SAU logo I made:
Ah... So that's how you designed it.
Interesting.
is he on the elgrand forum? the aus one... cause someone was on there asking about them as they were going to order them.
we got them on ours with the electronic damper controller and theyre awesome... ive had to raise it up a bit though, especially in the rear because there was no clearance between the rear axle and the bump stops so it was bottoming out on every pot hole and slight bump.
want to get some new wheels for it soon... white with polished lip.
btw - anyone know of anyone getting an RB25 or RB26 tuned in Moorabbin tonight? Cause someone has one on a Dyno somewhere and its getting f**king flogged! Last 2 hours hitting the limiter, doing a run nearly every minute.
Poor car.
yeah why would you buy wheels if you had your car for sale?
+30 9inch with 255/40 tyre. Flush enough for you? Too bad it will completely destroy my front guard haha
The tyre shop put one of my 9inch wheels on the front. Car looked weird with a 225 and a 255 on the back pair lol
*facepalm*
fuck off before I act on my temptation to hit you with a chair.
well i bought the wheels and then as the wheels were being put on i got the call that someone wants to see the car. so far iv been getting tyre kickers so thought meh will just go along with it. he came saw the car then gave the deposit next day. but wheels were not sold with the car and will keep em for the next car.
Environmental vandal.
WHAT WOULD BOB BROWN SAY?!!!oneone
Poor trees never hurt anyone.
woo, 3 trees coming down today, making room for the extension
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
