Anyone know of any electrician jobs paying 90k+ based in Melbourne? My current job is really giving me the shits, having to travel interstate at least a couple of weeks a month, when it should be shared around with the other tradesmen. I feel like a f**king puppet at the moment...
Just a few ideas that are going through my head at the moment. Just being overworked to the bone, when I was told that work would be shared around has really given me the irrates. Not to mention the full-blown argument that I had with both my bosses. Probably won't end up leaving, but just weighing up my options.
Might see if I can get into cruisy construction work again :)
sorry to hear juliette
hope its something simple, if there is no grinding, no chucks of cogs etc surely its something simple
on a good note all our plastering is done, finito! rangehood ready to go back in, all roof panels fixed (were sagging) and holes fixed up
tomrorow sanding mission and then undercoat and done wooohooo
Does anyone have any spare 3inch silicon hose bends? Im after a 90degree bend or 45degree bend, just want to borrow and/or buy if it fits!
My airpod sits too high and hits the bonnet, want to put a bend between the AFM and airpod so its sitting inside the vacant space where the airbox was! (or a bend between intake pipe/afm whatever works)
Plz help!
Thanks <3
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
