I haven't had the other 2 for agessss man :P
But yeah, Supra was meant to be gone today but the dead battery screwed me around.
MR2 should be 100% functional pretty soon :D Then I'll come on a cruise or even organise something myself.
Yeah cool!
Get your MR2 on!
I know another N/A R33 here that made 96rwkw from memory :P I won't name names though.
Was yours modified Leigh?
There's a few guys on Supra forums with 155rwkw or more. Pretty good effort for an N/A I reckon :D
even tho you may have an extra 10kw/tonne, the weight will be far more noticeable when turning, stopping and controlling in an oversteer... you know... those functions of your car that don't involve raw power.
put it this way, get the tail end out to 45 degrees in a poopra, a 300zx and a skyline, and see which one is easier to catch and bring back into line.
hey scott, where did your mate get the 5th season of its always sunny in philly?
cant find it on ebay anywhere
finally internets back, had to go through and see whats going on in the wasteland and i can see not much lol.
he got the 5th season from downloading it from isohunt.com
another really good show im getting into is sons of anarchy, you should check it out.
hmmm yeah have to have a look
also i like - eastbound and down
its pretty funny, got the guy from Hotrod the movie and Will Farrell
you get your wheels yet nick?
Nah man not yet :)
hopefully 2-3 weeks.... i want em bad though then i can start buying the carbon parts i want
atm i cant really cause itll be yellow car, white wheels and carbon lips/spoilers etc.... look shit
Wonder why delivery is taking so long Nick :)
haha cause it wasnt just delivery, when i ordered them they had to get made then shipped
from the latest update should be getting shipped this or next week :)
yeah haha fair nuff what carbon parts u getin?
my mate has carbon front lip looks hawt
haha yeh varis front lip, sideskirt and rear bar extensions, wing blade and vortex generator
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
