I must know about 10 of Beethovens Piano Sonata's... love playing that stuff.
Current favs are Bach Cello Suit No.1, makes me want to learn Cello and also playing Gymnopedie No.1 - Erik Satie. <3 <3 <3
thats awesome, my current fav of beethoven at the moment is moonlight sonata.
those professors are in MINT condition. beautiful in the flesh.
2k for 18x9.5 & 10 +18 3pc meisters? thats with trade in of my stuff. i rekon i might be able to get cheaper if i shop around
not a bad deal they are brand new rims/tyres yer?
thats the size i want. mine are 18x10 +25 and +15 plus two 18x9 +25 one bent as fk. its cos he needs to fix up rash and massive paint chips on mine b4 selling them that he sez 2k. but at the same time, i am giving him 5 pretty good spec, if a bit rough, wheels.
doesnt feel like a bargain
lol.
my wheels: 18x10 +25 f 18x10 +15 r. a little too mexican, and hits the drivers side upper control arm thingy on full lock right. also have a pair of 18x9 +25, one of which is bent.
he has: these. which he is asking 2k for as is, with trade in of all 6 of my wheels. i was mistaken, they arent completely perfect condition either. that was some other set i was asking him about
Yeah Jezza Boi!
Don't for get that!
my fav too. :D
Hell Yeah!
i agree, its my favourite too.
It's an all time fav!
Interesting mix.
I like the guitar one.
Arranged by Jerry C.
Matt (MattRach) rips it up!
lol.
yeh straight swap isnt great unless they tyres are in top nick cos the wheels need fixiing as it is.
but yeh your wheels must be hella mexican.
that's fine as it's a 4wd anyway
im keeping tyres. just swapping rims.
keep yours niggaaaaaa imo pics look mad at the drags of your car
lol yes it does look good. sometimes. car is too high but the main issue is that they hit the suspension on the front. 10 inch is too big
haha shaddap you. just cos i dont have coilovers. will go lower when i can afford it
phuck dat. on my budget, it'd have to be shitty ones. i like the way the car handles with the bilsteins that are in there. its just that if i need to adjust height, i need to get a workshop to do it for me - circlip adjustment. if/when i start work, i will probably just get threaded sleeves made up for my shockies and voila - adjustment
I think i've just blown my turbos tonight... A little pop and no +ve boost.
Have checked my piping in the garage but i'm afraid nothing has come loose!
Strange as the idle and everything is still fine.. not really any smoke.
If anyone has a pair of N1 Turbos for sale in vic please PM me.
Thanks.
Thanks.
Garrett GT2860 - 5 would be nice and yummy for you them
Thanks.
count grantleyish afaik
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
