Mebbe if u had tractor suspension Hamish u could have run lower than a 12.9! On that topic my front shocks are dead so will get coilovers soon.
Pat you looked like you were cruising down the quarter not racing lol
had issues with axle tramp and spinning in 2nd gear. Should be better next time.
Where was your fanta 33? Busy posing next to it? :(
c-c-c-commmboo breaker.
Shan u missed out on some goooooooooood duck.
and so did you Basti. shame shame.
FFFUUU. had to do an airport run mangs.
btw... does your mate still want those rims? i lost his number.
dunno, they have just copied the cube but given it a less interesting front end.
Agreed. The Rukus is a tremendously boring looking car, no character and overpriced.
try running with a peice of wood 3 meters by 3 meters into the wind
then drive a cube
u will be comftable with the car already
The Cube has a better drag coefficient than an R32 GT-R, a new WRX, BMW M3, Dodge Viper, MX-5...shall I keep going? :(
http://en.wikipedia.org/wiki/Automobile_drag_coefficient
nope, it was a cardboard cube. more specifically it was a three-dimensional solid object bounded by six square faces, facets or sides, with three meeting at each vertex. The cube can also be called a regular hexahedron and is one of the five Platonic solids. It is a special kind of square prism, of rectangular parallelepiped and of trigonal trapezohedron.
lol what are you doing down this way!?
you wasteland whore you
The Cube has a better drag coefficient than an R32 GT-R, a new WRX, BMW M3, Dodge Viper, MX-5...shall I keep going? :)
*snap on me then!
acceleration > drag coefficient
fly swatters have better drag coeffient than sledgehammers. guess what hurts more when it lands on your face?
also, no one fucks with someone running around with a sledgehammer.
chuck norris.
/thread
also, no one f**ks with someone running around with a sledgehammer.
haha next time mannn. umm i'll ask him tomoz for u. most probably does yeah. u kno Lalin dont u?
maybe, i dunno. i'm bad with faces and names. esp curries. they all look the same.
Just an FYI for everyone - Do NOT go to Amberley Wheel Alignments. They told me I had a bent strut and wheel hub then charged me a ridiculous amount.
I got 2 real mechanics to go over my car with me today. I have a slightly bent tie rod. That's it.
Fkn relieved now :P At least I know my car won't fall to bits.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
