according to work usa, the 9's are Odisk @ 96mm, the 9.5's are Adisk @ 83mm. curious enough to search lol
uhhh ALL works wheels come in A, B,C or O centre. You choose the centre based on the brakes you're running and what kind of concave etc you want.
just get whoever's buyin you the wheels or gettin em from to measure the lip for you if all you wanna know is how much dish you'll have. You can't tell that just by using the offset and width.
yes yes i knew that disk affects dish - just didnt know which was which, and i dont really care exactly how many mm of dish i will get. just bored and decided to learn something. now what i dont know is whether o disk will clear gtst brakes.
also it seems i'v broken my right hand shift button on the keyboard
FML, So as a condition of roadworthy I had to get my drivers side window working (previous owner disconnected as it wound itself up) So I took it to the auto-elec today and they rang me during the day to come get it........ FARK final cost= $360.46 wtf? just to fix my window are you serious????? :D
That's my gripe for the day :)
I was a year and a bit...
That's a fair while. I thought I was bad @ 6 months late.
If I got my license at 18 I would be getting my fulls in 4 days :) Unfortunately I've gotta wait til next year.
If I got my license at 18 I would be getting my fulls in 4 days :D Unfortunately I've gotta wait til next year.
LOLnoob....L2getlicensethedayyoucan.
I got my Ls the day I turned 16 and Ps the day I turned 17. I was even late to my PD/H/PE HSC exam because of it :)
At the time I was living out in the sticks. There was no friggin' way I was going to wait a single day longer than I had to to get my license.
At the age of 18 I had no interest in driving. I could walk/skate to school and friend's houses. I didn't even like cars at that stage.
When I started working I realised that I needed to drive. Did 15 hours on my L's and then fluked my P's test.
Once I started looking to buy a car I realised how awesome they were :)
had my L's at 16, P's on the day I turned 17, lost it by the age of 19. Full license at 21.
I'd have had my full by 19 if I hadn't lost it, but cos I lost it I went into the 3 year P-plate system instead of the 1 year P-plate. FFFUUU.
So you on full license now...
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
